Telnet stopped working on a few NI-3100's ??
I can still hook up a serial cable and terminal all day long.
but no telnet client will talk to it.
telnet is turned on and on the default port.
any thoughts?
John
    Are you using 4.x firmware?
    I don't know if it's been fixed yet but you need to enable SSH in order for telnet to work.
    It's been reported to tech support.
  • Enable SSH to make telnet work???
    Thats the second wonkiest thing if heard of this week!
    And it worked.
    Thanks!
    John
    A few days ago I updated my office and a few clients to the latest v. 4.1.419 and today noticed my telnet wasn't working and my logging function had't been working since the update cuz it couldn't connect either. I checked setting through the browser and telnet was already grouped with SSH so in this version they can't be enabled separately. So I rolled back to v. 3.60.453 and telnet instantly returned and through the browser there isn't even an option for SSH. I can't be the only one with this not working in the current sw version. WTF!
    Edit:
    Now I have to go see what damage this latest firmware did to those clients I updated. I was hoping for some benefits but I should have known better! Actually if their telnet isn't working their daily logs aren't being written and my daily SITREPs will have no message attached. I guess I should have been looking at those attachments to notice they weren't there since the update.
    Ok, this is related to SSH being enabled. Being a dumb a ssI was looking at security settings in my master browser not the system > server settings. In my defense I usually turn this s hit off it telnet not the browser and it has been a routine to turn off SSH since I don't need it. Any way I'm shocked that this has been fixed in the the current 4.x?? firmware. So all will be good as soon as I log in enable SSH and reboot then my logging should work again.
  • Not anything helpful, but I can confirm this. I turned off: System > Server > SSH and after a reboot was unable to telnet into the master. Never noticed this before, I usually don't change the server settings, I guess.
    After I re-enabled SSH I used telnet to to access the master and turn off SSH there (set ssh port > 0 > reboot). Although I could not telnet into the master after this, according to the webinterface SSH was still enabled. After a second reboot telnet just worked again... something does not seem right here. Probably won't be fixed, either.
    Also using firmware 4.1.419
    I doubt it will get fixed either and chances are my systems won't get upgraded to NX masters since I don't see a future in AMX so I don't even suggest upgrading when issues arise.
