IP CONTROL
Hello,
I am having difficulty programming a SHARP LED LC640U, using IP Protocol. This is my first experience trying IP. Take a look at my code and let me know where I have went wrong. Currently, none of the IP controls work. The switching for the Enova and Audio works.
'PROGRAM_NAME='9-259 Source Code'
DEFINE_DEVICE
dvTP = 10001:1:0 //AMX MXT-700i Touch Panel
dvMaster = 0:1:0 //Enova DVX2100HD Master
dvSHARP_LED1 = 0:3:0 //Sharp LED_1
dvSHARP_LED2 = 0:4:0 //Sharp LED_2
dvEnovaSwitch = 5002:1:0 //Enova DVX2100HD Switcher
dvVol1 = 5002:1:0 //Enova Volume
DEFINE_VARIABLE
INTEGER nTVStatus
INTEGER nClear
CHAR MON1IPAddress[15]= '192.168.0.108'
LONG MON1_IP_Port = 10002
CHAR MON2IPAddress[15]= '192.168.0.109'
LONG MON2_IP_Port = 10002
DEFINE_CONSTANT
tvON = 11
tvOFF = 12
Clear = 5
DEFINE_START
fnClearAll()
DEFINE_FUNCTION fnSystemOn()
SEND_COMMAND dvEnovaSwitch, "'VIDEO_MUTE DISABLED'"
WAIT 5
IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RSPW2 ',$0D" //Requests Power ON
IP_CLIENT_CLOSE(3)
WAIT 5
SEND_STRING dvSHARP_LED1, "$02,'POWR1 ',$0D" //Powers On LED
IP_CLIENT_CLOSE(3)
WAIT 5
IP_CLIENT_OPEN(4,MON2IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RSPW2 ',$0D" //Requests Power ON
IP_CLIENT_CLOSE(4)
WAIT 5
SEND_STRING dvSHARP_LED2, "$02,'POWR1 ',$0D" //Powers On LED
IP_CLIENT_CLOSE(4)
WAIT 5
SEND_COMMAND dvEnovaSwitch, "'?AUDIO-MUTE'" //Requests Mute Status
WAIT 5
SEND_COMMAND dvEnovaSwitch, "'AUDIO_MUTE ENABLED'" //Enables Mute
nTVStatus = tvON
DEFINE_FUNCTION fnSystemOff()
SEND_STRING dvSHARP_LED1, "$02,'POWR0 ',$0D" //Powers Off LED
IP_CLIENT_CLOSE(3)
WAIT 5
SEND_STRING dvSHARP_LED2, "$02,'POWR0 ',$0D" //Powers Off LED
IP_CLIENT_CLOSE(3)
WAIT 5
nTVStatus = tvOFF
DEFINE_FUNCTION fnClearAll()
WAIT 5
SEND_COMMAND dvEnovaSwitch, "'VIDEO_MUTE ENABLED'"
DEFINE_MUTUALLY_EXCLUSIVE
([dvTP,5],[dvTP,8],[dvTP,11],[dvTP,14],[dvTP,65],[dvTP,17],[dvTP,18]) //LED 1
([dvTP,6],[dvTP,9],[dvTP,12],[dvTP,15],[dvTP,65],[dvTP,17],[dvTP,18]) //LED 2
([dvTP,7],[dvTP,10],[dvTP,13],[dvTP,16],[dvTP,65],[dvTP,17],[dvTP,18]) //Both
([dvTP,7],[dvTP,10],[dvTP,13],[dvTP,16],[dvTP,5],[dvTP,8],[dvTP,11],[dvTP,14],[dvTP,65],[dvTP,17],[dvTP,18]) //Both and 1
([dvTP,7],[dvTP,10],[dvTP,13],[dvTP,16],[dvTP,6],[dvTP,9],[dvTP,12],[dvTP,15],[dvTP,65],[dvTP,17],[dvTP,18]) //Both and 2
([dvTP,61]..[dvTP,65],[dvTP,17],[dvTP,18]) //Audio
//Volume ([dvTP,4],[dvTP,50],[dvTP,51]) //Volume
DEFINE_EVENT
LEVEL_EVENT [dvVol1,1]
SEND_LEVEL dvTP,1,level.value
BUTTON_EVENT [dvTP,17]
PUSH:
fnSystemOn()
BUTTON_EVENT [dvTP,18]
PUSH:
fnClearAll()
WAIT 30
fnSystemOff()
// Switch to page Logo
SEND_COMMAND dvTP,"'@PPN-[prompt]Shutdown'"
WAIT 50
//Wait 5 seconds Switch to Logo
SEND_COMMAND dvTP,'PAGE-Logo'
TO[BUTTON.INPUT]
BUTTON_EVENT [dvTP,22]
BUTTON_EVENT [dvTP,23]
BUTTON_EVENT [dvTP,24]
BUTTON_EVENT [dvTP,25]
BUTTON_EVENT [dvTP,26]
BUTTON_EVENT [dvTP,27]
BUTTON_EVENT [dvTP,28]
BUTTON_EVENT [dvTP,29]
BUTTON_EVENT [dvTP,30]
BUTTON_EVENT [dvTP,31]
BUTTON_EVENT [dvTP,32]
BUTTON_EVENT [dvTP,33]
PUSH:
SWITCH(BUTTON.INPUT.CHANNEL)
CASE 22: IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'POWR0 ',$0D" //Power Off
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
nTVStatus = tvOFF
CASE 23: IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'POWR1 ',$0D" //Power On
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
nTVStatus = tvON
CASE 24: IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'WIDE0 ',$0D" //Aspect Tog
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 25: IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'WIDE8 ',$0D" //Dot by Dot
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 26: IP_CLIENT_OPEN(3,MON1IPAddress,MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'ITGDx ',$0D" //Input Tog
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 27: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY38 ',$0D" // Menu
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 28: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY46 ',$0D" //Exit
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 29: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY41 ',$0D" //Up Arrow
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 30: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY43 ',$0D" //L Arrow
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 31: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY42 ',$0D" //Down Arrow
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 32: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY44 ',$0D" //Rt Arrow
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
CASE 33: IP_CLIENT_OPEN(3,MON1IPAddress, MON1_IP_Port,1)
SEND_STRING dvSHARP_LED1, "$02,'RCKY40 ',$0D" //Enter
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
BUTTON_EVENT [dvTP,34]
BUTTON_EVENT [dvTP,35]
BUTTON_EVENT [dvTP,36]
BUTTON_EVENT [dvTP,37]
BUTTON_EVENT [dvTP,38]
BUTTON_EVENT [dvTP,39]
BUTTON_EVENT [dvTP,40]
BUTTON_EVENT [dvTP,41]
BUTTON_EVENT [dvTP,42]
BUTTON_EVENT [dvTP,43]
BUTTON_EVENT [dvTP,44]
BUTTON_EVENT [dvTP,45]
PUSH:
CASE 34: IP_CLIENT_OPEN(4,MON2IPAddress,MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'POWR0 ',$0D" //Power Off
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
nTVStatus = tvOFF
CASE 35: IP_CLIENT_OPEN(4,MON2IPAddress,MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'POWR1 ',$0D" //Power On
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
nTVStatus = tvON
CASE 36: IP_CLIENT_OPEN(4,MON2IPAddress,MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'WIDE0 ',$0D" //Aspect Tog
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 37: IP_CLIENT_OPEN(4,MON2IPAddress,MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'WIDE8 ',$0D" //Dot by Dot
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 38: IP_CLIENT_OPEN(4,MON2IPAddress,MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'ITGDx ',$0D" //Input Tog
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 39: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY38 ',$0D" // Menu
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 40: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY46 ',$0D" //Exit
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 41: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY41 ',$0D" //Up Arrow
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 42: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY43 ',$0D" //L Arrow
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 43: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY42 ',$0D" //Down Arrow
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 44: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY44 ',$0D" //Rt Arrow
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
CASE 45: IP_CLIENT_OPEN(4,MON2IPAddress, MON2_IP_Port,1)
SEND_STRING dvSHARP_LED2, "$02,'RCKY40 ',$0D" //Enter
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
BUTTON_EVENT [dvTP,5]
BUTTON_EVENT [dvTP,6]
BUTTON_EVENT [dvTP,7]
BUTTON_EVENT [dvTP,61]
BUTTON_EVENT [dvTP,8]
BUTTON_EVENT [dvTP,9]
BUTTON_EVENT [dvTP,10]
BUTTON_EVENT [dvTP,62]
BUTTON_EVENT [dvTP,11]
BUTTON_EVENT [dvTP,12]
BUTTON_EVENT [dvTP,13]
BUTTON_EVENT [dvTP,63]
BUTTON_EVENT [dvTP,14]
BUTTON_EVENT [dvTP,15]
BUTTON_EVENT [dvTP,16]
BUTTON_EVENT [dvTP,64]
BUTTON_EVENT [dvTP,65]
PUSH:
CASE 5: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI1O1'"
ON[BUTTON.INPUT]
CASE 6: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI1O2'"
ON[BUTTON.INPUT]
CASE 61: SEND_COMMAND dvEnovaSwitch, "'CLAUDIOI1O1'"
ON[BUTTON.INPUT]
SEND_COMMAND dvEnovaSwitch, "'AUDIO_MUTE DISABLED'"
CASE 8: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI2O1'"
ON[BUTTON.INPUT]
CASE 9: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI2O2'"
ON[BUTTON.INPUT]
CASE 62: SEND_COMMAND dvEnovaSwitch, "'CLAUDIOI2O1'"
ON[BUTTON.INPUT]
CASE 11: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI3O1'"
ON[BUTTON.INPUT]
CASE 12: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI3O2'"
ON[BUTTON.INPUT]
CASE 63: SEND_COMMAND dvEnovaSwitch, "'CLAUDIOI3O1'"
ON[BUTTON.INPUT]
CASE 14: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI4O1'"
ON[BUTTON.INPUT]
CASE 15: SEND_COMMAND dvEnovaSwitch, "'CLVIDEOI4O2'"
ON[BUTTON.INPUT]
CASE 64: SEND_COMMAND dvEnovaSwitch, "'CLAUDIOI4O1'"
ON[BUTTON.INPUT]
CASE 65: fnClearAll()
TO[BUTTON.INPUT]
nClear = Clear
DEFINE_PROGRAM
IF (TIME = '23:59:00')
fnClearAll()
fnSystemOff()
SEND_COMMAND dvTP, '@PPN-[prompt]Shutdown'
WAIT 50
SEND_COMMAND dvTP,"'PAGE-Logo'"
//button1,button2,button3 = button numbers on TP
SYSTEM_CALL [1]'VOL1'(dvTP,51,50,4,dvVOL1,24,25,199)'
DEFINE_DEVICE
DEFINE_VARIABLE
INTEGER nTVStatus
INTEGER nClear
DEFINE_CONSTANT
tvON = 11
tvOFF = 12
Clear = 5
DEFINE_START
fnClearAll()
WAIT 5
IP_CLIENT_CLOSE(3)
WAIT 5
IP_CLIENT_CLOSE(3)
WAIT 5
IP_CLIENT_CLOSE(4)
WAIT 5
IP_CLIENT_CLOSE(4)
WAIT 5
WAIT 5
nTVStatus = tvON
IP_CLIENT_CLOSE(3)
WAIT 5
IP_CLIENT_CLOSE(3)
WAIT 5
nTVStatus = tvOFF
WAIT 5
DEFINE_EVENT
PUSH:
fnSystemOn()
PUSH:
fnClearAll()
WAIT 30
fnSystemOff()
WAIT 50
TO[BUTTON.INPUT]
PUSH:
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
nTVStatus = tvOFF
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
nTVStatus = tvON
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(3)
TO[BUTTON.INPUT]
PUSH:
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
nTVStatus = tvOFF
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
nTVStatus = tvON
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
IP_CLIENT_CLOSE(4)
TO[BUTTON.INPUT]
PUSH:
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
ON[BUTTON.INPUT]
TO[BUTTON.INPUT]
nClear = Clear
DEFINE_PROGRAM
fnClearAll()
fnSystemOff()
WAIT 50
I would open the client on your power on function, then put the actual command in a queue that doesn't process until a online event occurs. You might need an additional delay between when the power on command goes to the TV and when it's ready for other commands as well. Again, it you queue your commands, you can hold up processing on it based on that. Depending on the device, I might never close the connection, but make a delay on an offline event that reconnects it after about 20 seconds. You probably want something like anyway in case it disconnects on you. Closing it on power off isn't a horrible thing, but may not be necessary.
Thanks for the feedback. I had that problem with the RS232 code, so I am attempting to try IP but I've never coded for IP before. Is there something I'm missing, I can't get any function to work.
Note that the nature of the NetLinx processes are such that the mail line does not execute on every tick of the clock. If this precise time is specified, and the processor is in some other task at that tick, it will not match in your main line, and will miss your IF. You need a wider target, or a greater-than.
John,
Although I appreciate your help, that's irrelevant to my question. Are you able to provide help relevant to anything I've asked?
Matt
I would give you the exact same advice as Dave. Manage your IP connection and implement a queue, that should resolve your issues.
To test new devices for IP I typically do something like this:
With that and using "Control a Device" from within NS you can pulse channel 252 to open the connection and pulse 254 to send whatever string you put into sTestString in the debug window.
Also, when posting code you should use the proper forum tags around your code so it's easier to read for those of us attempting to help.
Nope, others are doing that. Sorry to distract you with other issues in your posted code.
On a slight tangent, you can send a non documented command to the Sharp TVs BEFORE turning them off that keeps the RS232 alive so you can switch it on again !!:
// tell the TV NOT to power off the RS232 -- otherwise the energy saver stops us bringing it on again
send_command vdvDISPLAY2, 'PASSTHRU=RSPW0001'
WAIT 20 PULSE[vdvDISPLAY2, 28] // now we can KITCHEN TV OFF
P.S. Using the AMX Duet module for the Sharp LED TVs
Sometimes the TV expects spaces and not zeroes, e.g. SEND_STRING dvTV, "'RSPW 1',$0D" I ran into a new model recently that actually accepted a 0,1, or 2 as parameters to the RSPW command, where 0 means "don't respond to power on," 1 is supposed to be for RS232 control and 2 for IP control. Even though we were controlling the TV via RS232, only 'RSPW 2' worked.
Would rather know ahead of time as we deal with a lot of Sharps LCDs...
'twas the LC-80LE650U.
Thanks again.
Waits are useless when it comes to IP code. You can never predict how long some IP function is going to take since it depends on the network. It has to be event based to work reliably. You have the online and offline events so that's all you really need to know for sending commands. If its online, send the command immediately, if not, open the port, and once its online then send the command immediately. Adding a wait simply adds a red herring to the issue and usually ends up adding unnecessary delays. Some servers will keep the connection open so you can send one packet after another, and others will close the connection after every packet, so with event triggered IP code, it doesn't matter, the right thing will always occur depending on the state of the connection.
CASE 2: // SELECT LCD Left Front Power Btn
IF (nDisp_2_Pwr = 0)
IP_CLIENT_OPEN(dvLCD_1.PORT,cLCD_1_IP,LCD_IP_PORT,1)
WAIT 1 {SEND_STRING dvLCD_1,"$0D,$0A"}
WAIT 2 {SEND_STRING dvLCD_1,"$0D,$0A"}
WAIT 3 {SEND_STRING dvLCD_1,Disp_FCN[Disp_LCD_Pwr_ON]} // POWER ON LCD
WAIT 4 {SEND_STRING dvLCD_1,Disp_FCN[Disp_LCD_HDMI]} // Set input to HDMI
WAIT 5 {IP_CLIENT_CLOSE(dvLCD_1.PORT)}
nDisp_2_Pwr = 1
ELSE IF (nDisp_2_Pwr = 1)
WAIT 3 {SEND_STRING dvLCD_1,Disp_FCN[Disp_LCD_Pwr_OFF]} // POWER Off LCD
WAIT 4 {IP_CLIENT_CLOSE(dvLCD_1.PORT)}
nDisp_2_Pwr = 0
BREAK
When the IP port is opened it will create an online event. This online event handler is the place where you want to start sending commands.
