Username and PW for TP Web interface
My work recently had a security audit, and I was asked to add a username and password to a set of IP's. When I checked the IP's, they were all my TP's. I have looked through all the settings and the only username and password I can find is for TP to Master communication, not locking someone out from accessing it over the web/network. The only other option I can think of is setting a pass code on the TP, but that doesn't just lock down the web interface, but the physical TP as well. I can do that if necessary, but would prefer not to as these TP's are in courtrooms and often used by private attorneys and don't need that headache. I merely want to secure the IP and disable VNC and Telnet. Can someone point me in the right direction?
    You can disable VNC by simply turning off G4 Web Control on the panel. I'm not sure about the Telnet, but I can't see where it represents any kind of risk, you are very limited in what you can do there. Of course, auditors aren't necessarily reasonable about stuff like that.
  • PhreaKPhreaK Posts: 966
    I think you will find that this white paper will be your friend.
