M2M - Slave not providing Relay Feedback consistently...
Good AM.
I have a system with an Enova DGX(Main Program - Controls everything) and NI3100(Slave Program - Does nothing).
The Enova Master is running on the Main Program.
The NI3100 is running the Slave Program which essentially does nothing (Devices are defined);
(and certainly nothing with the Relays)
Sometimes, when the NI3100 relays are turned on/off by the Main Program the feedback does not occur.
Rebooting the NI3100 corrects the no feedback issue for a little while - a few days.
Without rebooting the NI3100, I can connect to the Enova Master and control the relays with no problem - still does not produce Channel Event On/Off Feedback.
Anyone with an idea why the Feedback does not consistently work?
DEFINE_EVENT
CHANNEL_EVENT[dv1Relay, RELAY_1]
	ON:
		LightingControl.Switches[Channel.Channel].IsOn = True;
	OFF:
		LightingControl.Switches[Channel.Channel].IsOn = False;
DEFINE_EVENT
BUTTON_EVENT[tpsEnvironment, btnsLightingSwitches]
	PUSH:
		Stack_Var Integer index;
		index = Button.Input.Channel - OFFSET_LIGHT_SWITCH;
		Handle_LightingSwitchSelection(LightingControl, index, !LightingControl.Switches[Index].IsOn);
Define_Function Handle_LightingSwitchSelection(TLightingControl LC,
	Integer Index, Integer bOn)
// Fake Feedback; the Slave NI3100 is not, consistently,
//	providing the Channel On/Off for the relays.
	LC.Switches[Index].IsOn = bOn;
	if ( bOn )
		TDevCommand_Execute(LC.Switches[Index]._On);
	}else
		TDevCommand_Execute(LC.Switches[Index]._Off);
  • DavidRDavidR Posts: 62
    I've been told to limit the code running in DGX masters... try running all the code in the NI3100 and see what happens.
  • DavidR wrote: »
    Thank you for the response.
    I will give it a go.
    Do you know the reason to limit code running on DGX Masters?
    I was told there is some processor overhead with DGX master running switcher functions. I was experiencing similar issues as you and now remove all code DGX units until it gets resolved. my problems all went away once i got the code out of the DGX.
    The firmware that the DGX units are on is an early rev of v4 master firmware (379 i recall). I'm testing 403 and am still working issue out with it.
  • Thanks, it really sucks that we have to do the testing...
    I will remove the code from the Enova Master.
    If you have the time let me know how the testing with 403 goes.
  • Now that I think about it:
    [RANT]
    AMX; What the hell is the point of having an NI3100 Onboard Master controller if you can't use it!
    [/RANT]
    exactly...
  • champchamp Posts: 261
    are you sure?
    As far as I'm aware the master in the DGX has nothing to do with the switcher, you can't get any diagnostics about the unit from code, and you can't even get notified about switches made from the front panel.
    If anyone has some facts to prove me wrong please post them.
  • AMX-TS finally got back to me on this:
    Update the FW on both Masters (Device 0) to v4.1.403.
    - FW v4.1.403 Devices don't like talking to FW v3.60.455 Devices and vis-versa...
    Make sure to define the Relays in both programs.
    TS insists that what I have done will certainly work.
    Have not tried this yet as the FW has only been out since 2013-12-02,
    will wait to hear if anyone else discovers issues with this release.
    I am not sure if there is a separate processor for Switching...
    That would be a good question to ask.
    most likely that was my issue then... I didn't want to update to v4 on my 3100s so they were running v3 still.
