Convert char string in hex ?
Hey
ok it's probably a stupid question but I'm unable to find the way to convert literally a char string in hex. For example I have a string 0AB0FF that I need to convert in hex type au $0A,$B0,$FF
Vincèn
Vincèn
Here is a small section of code that will take the ascii hex you provide and populate an array with the decimal numbers you want. Remember, an integer can be represented as decimal or as hex interchangeably -- i.e. there is no difference to the process between decimal and hex.
local_var integer icount local_var integer iii //hex_string contains the ascii hex representation you want as integers if(length_string(hex_string) % 2) { hex_string = "'0',hex_string" // pad the string with '0' if length is odd } iCount = length_string(hex_string)/2 for(iii= icount; iii ; iii--) { nFromHex[iii] = hextoi(right_string(hex_string,2)) // nFromHex is an appropriate array to contain the result hex_string = left_string(hex_string,length_string(hex_string)-2) }If you run this on the text you proposed, you get a three element array containing {$A,$B0,$FF}
or {10,176,255} Type as either 8 bit character arrays or integer arrays as desired.
edited:
hextoi() does indeed return a 32 bit unsigned integer. But, if you assign the result to a 16 bit integer, as I dis -- well, that's clear.
So, it's probably easier to use hextoi() on the whole string and then extract what is wanted by using bitwise and and shifting bits.
