Enova DVX2100HD Feedback
Hi there,
Attempting to achieve feedback into some text boxes I created for my Enova DVX2100HD. Not sure what I'm doing wrong, but I can't seem to get any sort of text feedback. I've read the manual front to back and the command for input query appears to be correct. Here's my code:
"DATA_EVENT[dvENOVA]
ONLINE:
SEND_COMMAND dvENOVA, "'?INPUT-VIDEO,1'"
SEND_COMMAND dvENOVA, "'?INPUT-VIDEO,2'"
STRING:
SEND_COMMAND dvTP,"'^TXT-55,0,',DATA.TEXT"
SEND_COMMAND dvTP,"'^TXT-56,0,',DATA.TEXT"
IF(FIND_STRING(DATA.TEXT,'SWITCH-L',1))
SELECT
ACTIVE(FIND_STRING(DATA.TEXT,'>I1O1',1)):
SEND_COMMAND dvTP, "'^TXT-55,0,RACK-PC'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I1O2',1)):
SEND_COMMAND dvTP, "'^TXT-56,0,RACK-PC'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I2O1',1)):
SEND_COMMAND dvTP, "'^TXT-55,0,VGA Front'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I2O2',1)):
SEND_COMMAND dvTP, "'^TXT-56,0,VGA Front'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I3O1',1)):
SEND_COMMAND dvTP, "'^TXT-55,0,HDMI Rear'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I3O2',1)):
SEND_COMMAND dvTP, "'^TXT-56,0,HDMI Rear'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I4O1',1)):
SEND_COMMAND dvTP, "'^TXT-55,0,VGA Rear'"
ACTIVE(FIND_STRING(DATA.TEXT,'>I4O2',1)):
SEND_COMMAND dvTP, "'^TXT-56,0,VGA Rear'"
  • TechFreakTechFreak Posts: 39
    DVX Feedback
    With the DVX being a native device, does it respond with strings or commands. I use feedback on the video and audio levels (50 and 51) LEVEL_EVENT to track current source selected, which is where you could put your TP text feedback.
    Frank Krauch
  • TechFreak wrote: »
    Frank Krauch
    Hmm, I'm not the best programmer but that doesn't make sense to me. Why would the manual give you a query command, but the Enova not actually provide feedback?
    mjones2620 wrote: »
    It does provide feedback, but your code is trying to parse the feedback on a STRING handler. Because it is a native device, the feedback is handled in a COMMAND handler of the DATA_EVENT. Change your STRING: to COMMAND: and it should work as you intend. I was also offering another way of tracking the feedback on the LEVEL_EVENT of the Audio and Video levels.
    Frank Krauch
    Frank Krauch
    Ahhhhhhhhhhhh I totally overlooked that!
