Netlinx Crash when try Using Debugging
Hi All,
recently, when i try the debugging function
if i want to add a variables from list. the application is crashing.
someone else having this problem.
  • the8thstthe8thst Posts: 470
    Try clearing out the "C:\Users\*user_name*\AppData\Local\Temp" folder. AMX likes to store a lot in there and I have had issues with too many instances of duet transfer items building up in the folder and causing NS to crash.
    Make sure your project was compiled with debug turned on. I'm not sure if that will cause a crash, but it certainly won't work if it's off, and default is off. Also, I have found that older processors are more likely to choke on watch variables that are too complex, or if you have too many being watched at once.
  • RaphayoRaphayo Posts: 111
    I found it came from a custom module create to control a device. if more than 1 instance of that module is currently use. Netlinx Studio Crash when using debug.
    any clue on that.
    it can came from the way variable are use inside the module.
    thanks
    PMRaphayo
    Please post your code around the module declaration (DEFINE_MODULE .....)
    Perhaps it's just a little error there.
    Module_NAME='LgMonitorModule' (DEV dvport, DEV dvtp, integer nButton[])
    (*  FILE_LAST_MODIFIED_ON: 04/05/2006  AT: 09:00:25        *)
    (* System Type : NetLinx                                   *)
    (* REV HISTORY:                                            *)
    (* BUTTON AND TEXT BOX DEFINITIONS
    1-  ATV Input
    2-  AV1 Input
    3-  AV2 input
    4-  Component input
    5-  VGA input
    6-  HDMI1 Input
    7-  HDMI2 Input
    20  Power Off
    21  Power On
    23  Mute On
    30  Volume up
    31  Volume down
    84
    85  Online/Offline
    END OF BUTTON AND TEXT BOX DEFINITIONS*)
    (* START OF LEVEL DEFINITIONS
    86  Volume Level
     End OF LEVEL DEFINITIONS*)
        $History: $
    (*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
    DEFINE_DEVICE
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    Integer False = 0
    Integer True = 1
    //TLLG	= 6 // TimeLine for LG Monitor1 Polling
    CHAR LG_Power_ON[]={'k','a',$20,'0','1',$20,'0','1',$0d} // On
    CHAR LG_Power_OFF[]={'k','a',$20,'0','1',$20,'0','0',$0d} // Off
    CHAR LG_Power_Get[] = {'k','a',$20,'0','1',$20,'F','F',$0d} // Get
    CHAR LG_DTV1[] = {'x','b',$20,'0','1',$20,'0','0',$0d} // DTV1
    CHAR LG_DTV2[] = {'x','b',$20,'0','1',$20,'0','1',$0d} // DTV2
    CHAR LG_ATV1[] = {'x','b',$20,'0','1',$20,'1','0',$0d} // ATV1
    CHAR LG_ATV2[] = {'x','b',$20,'0','1',$20,'1','1',$0d} // ATV2
    CHAR LG_AV1[] = {'x','b',$20,'0','1',$20,'2','0',$0d} // AV1
    CHAR LG_AV2[] = {'x','b',$20,'0','1',$20,'2','1',$0d} // AV2
    CHAR LG_AV3[] = {'x','b',$20,'0','1',$20,'4','0',$0d} // Component1
    CHAR LG_AV4[] = {'x','b',$20,'0','1',$20,'4','1',$0d} // Component2
    CHAR LG_RGB[] = {'x','b',$20,'0','1',$20,'6','0',$0d} // RGB
    CHAR LG_HD1[] = {'x','b',$20,'0','1',$20,'9','0',$0d} // HDMI 1
    CHAR LG_HD2[] = {'x','b',$20,'0','1',$20,'9','1',$0d} // HDMI 2
    CHAR LG_HD3[] = {'x','b',$20,'0','1',$20,'9','2',$0d} // HDMI 3
    CHAR LG_Source_Get[] = {'x','b',$20,'0','1',$20,'F','F',$0d} //Get Input
    CHAR LG_Volume_Get[] = {'k','f',$20,'0','1',$20,'F','F',$0d} //Get Volume
    CHAR LG_Volume_On[] = {'k','e',$20,'0','1',$20,'0','1',$0d} //Mute Off
    CHAR LG_Volume_Off[] = {'k','e',$20,'0','1',$20,'0','0',$0d} //Mute On
    CHAR LG_Mute_Get[] = {'k','e',$20,'0','1',$20,'F','F',$0d} //Mute Get
    Integer nLG_Warmdly = 100	// 10 Sec.
    Integer nLG_ReadyOff = 150	// 15 Sec.
    Integer nLG_Cooldly = 150	// 15 Sec.
    Integer nLG_Cmd = 30	// 3 Sec.
    (*              DATA TYPE DEFINITIONS GO BELOW             *)
    DEFINE_TYPE
    (*               VARIABLE DEFINITIONS GO BELOW             *)
    DEFINE_VARIABLE
    volatile integer nSelection = 0 // Last Button Press
    volatile integer DebugLgMonitorModule = 0
    //LONG TLLGMonitorTime[4]={2000,2000,2000,2000}
    volatile integer nLGLock = 0		//LGNotReady
    volatile integer nLGOffreq = 0	//LG Power Off Request
    volatile integer nLGOnreq = 0	//LG Power On Request
    volatile integer nLGDly	 = 0	//LG Delay
    volatile integer nLGOn = 0		//LG power state
    volatile integer nLGOff	= 1	//LG Power state
    volatile integer nLGReady = 1	//LG is ready
    volatile integer nLGWarm = 0		//LG Warming
    volatile integer nLGCool = 0		//LG Cooling
    volatile integer nLGr2Off = 0	//LG Ready to Off
    volatile integer nLGr2On = 0		//LG Ready to On
    volatile integer nLGBusy = 0		//LG is Fully Busy
    volatile integer nLGSequence = 1 	//LG Command Sequence 1: Power, 2: Source, 3: Volume
    volatile integer nLGPowerFb = 0	//LGMonitor Power Feedback
    volatile integer nLGSourceFb = 0	//LGMonitor Source Feedback
    volatile integer nLGVolumeFb = 0	//LGMonitor Volume Feedback
    volatile integer nLGMuteFb = 0	//LGMonitor Mute Feedback
    (*               LATCHING DEFINITIONS GO BELOW             *)
    DEFINE_LATCHING
    (*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
    DEFINE_MUTUALLY_EXCLUSIVE
    (nLGOnreq,nLGOffreq) // One or the other not the both of them should be request
    (*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
    (* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
    (* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
    DEFINE_FUNCTION fnCLEAR_INPUT()
        STACK_VAR INTEGER i
        for(i=1;i<=7;i++)
    	OFF[dvport,nBUTTON[i]]
    DEFINE_CALL 'LGPower' (nLGPower)// Power Selection
     IF(!nLGDly)
        SWITCH (nLGPower)
    	CASE 1:
    	    ON[nLGDly]
    	    ON[nLGLock]
    	    WAIT nLG_Warmdly off[nLGdly]
    	    WAIT nLG_ReadyOff off[nLGLock]
    	    on[nLGOn]
    	    on[nLGOnreq]
    //	    nLGSequence = 1
    	    send_string dvport,LG_Power_ON
    	DEFAULT:
    	    ON[nLGDly]
    	    ON[nLGLock]
    	    wAIT nLG_Cooldly off[nLGdly]
    	    WAIT nLG_cooldly OFF[nLGLock]
    //	    nLGSequence = 1
    	    SEND_STRING dvport,LG_Power_OFF
    	    off[nLGOn]
    	    on[nLGOffreq]
    DEFINE_CALL 'LGInput' (Integer nLGInput) // Input Selection
        IF(!nLGDly)
    	SWITCH (nLGPowerFb)
    	    CASE 1:
    		ON[nLGDly]
    		WAIT nLG_Cmd OFF[nLGDly]
    //		nLGSequence = 2
    		select
    		    active(nLGInput=10): SEND_STRING dvport,LG_ATV1
    		    active(nLGInput=20): SEND_STRING dvport,LG_AV1
    		    active(nLGInput=21): SEND_STRING dvport,LG_AV2
    		    active(nLGInput=40): SEND_STRING dvport,LG_AV3
    		    active(nLGInput=60): SEND_STRING dvport,LG_RGB
    		    active(nLGInput=90): SEND_STRING dvport,LG_HD1
    		    active(nLGInput=91): SEND_STRING dvport,LG_HD2
    	    DEFAULT:
    		ON[nLGDly]
    		ON[nLGLock]
    		on[nLGOn]
    		on[nLGOnreq]
    //		nLGSequence = 1
    		WAIT_UNTIL (!nLGdly)
    //		    nLGSequence = 2
    		    if(DebugLgMonitorModule) send_string 0,"'dvLG Input Select:',itoa(nLGInput)"
    		    select
    DEFINE_CALL 'LGVolume' (integer nLGValue) // Volume Control
        IF(nLGPowerFb)
    	//ON[nLGDly]
    	//WAIT nLG_Cmd OFF[nLGDly]
    //	nLGSequence = 3
    	SEND_STRING dvport,"'kf',$20,'01',$20,format('%02X',nLGValue),$0d"
    	if(DebugLgMonitorModule) SEND_STRING 0,"'kf',$20,'01',$20,format('%02X',nLGValue),$0d"
    DEFINE_CALL 'LGMute' (nLGMute)// Mute Selection
        IF(nLGPowerFb)
    //	nLGSequence = 3
    	SWITCH (nLGMute)
    	    CASE 1:
    		send_string dvport,LG_Volume_On
    	    DEFAULT:
    		SEND_STRING dvport,LG_Volume_Off
    (*                STARTUP CODE GOES BELOW                  *)
    DEFINE_START
    (*                THE EVENTS GO BELOW                      *)
    DEFINE_EVENT
    timeline_event[TLLG]
        if(nDebugLG) send_string 0,"'dvLG TimeLine Sequence:',itoa(timeline.sequence)"
        switch(Timeline.Sequence)
    	Case 1:
    	    if(nDebugLG) send_string 0,"'Polling Power'"
    	    nLGSequence = Timeline.Sequence
    	    send_String dvport, LG_Power_Get
    	Case 2:
    	    if(nDebugLG) send_string 0,"'Polling Source'"
    	    send_String dvport, LG_Source_Get
    	Case 3:
    	    if(nDebugLG) send_string 0,"'Polling Volume'"
    	    send_String dvport, LG_Volume_Get
    	Case 4:
     	    nLGSequence = 1
     	    if(nLGOnreq)
    		if(nDebugLG) send_string 0,"'LG Resquest On Send'"
    		send_String dvport, LG_Power_ON
    	    if(nLGOffreq)
    		if(nDebugLG) send_string 0,"'LG Resquest Off Send'"
    		send_String dvport, LG_Power_OFF
    data_event[dvport]
        online:
    	if(DebugLgMonitorModule) send_string 0,"'LG ',itoa(data.device.number),' Online',$0d"
    	send_command dvport,'SET BAUD 9600,N,8,1'
    	wait 30 send_String dvport, LG_Power_Get
    	wait 40 send_string dvport, LG_Source_Get
    	wait 50 send_String dvport, LG_Volume_Get
    	wait 60 send_string dvport, LG_Mute_Get
    	on[dvtp,nbutton[85]]
    	//timeline_create(TLLG,TLLGMonitorTime,4,TIMELINE_relative,timeline_repeat)
        offline:
    	if(DebugLgMonitorModule) send_string 0,"'LG ',itoa(data.device.number),' Offline',$0d"
    	//timeline_kill(TLLG)
    	off[dvtp,nbutton[85]]
        string:
    	stack_var Char Cdump[50]
    	if(DebugLgMonitorModule) send_string 0,"'LG ',itoa(data.device.number),' string: ',data.text"
    	//timeline_pause(TLLG)
    	cdump = remove_string(data.text,'OK',1)
    	select
    	    active(cdump = 'a 01 OK'):
    		nLGPowerFb=atoi(Left_String(data.text,2))
    		nLGon = nLGPowerFb
    	    active(cdump = 'b 01 OK'):
    		fnCLEAR_INPUT()
    		nLGSourceFb=atoi(Left_String(data.text,2))
    		switch(nLGSourceFb)
    		    case 10: on[dvtp,nbutton[1]]
    		    case 20: on[dvtp,nbutton[2]]
    		    case 21: on[dvtp,nbutton[3]]
    		    case 40: on[dvtp,nbutton[4]]
    		    case 60: on[dvtp,nbutton[5]]
    		    case 90: on[dvtp,nbutton[6]]
    		    case 91: on[dvtp,nbutton[7]]
    	    active(cdump = 'e 01 OK'):
    		nLGMuteFb=(atoi(Left_String(data.text,2)))
    	    active(cdump = 'f 01 OK'):
    		nLGVolumeFb=HEXTOI(Left_String(data.text,2))
    		send_level dvtp,nbutton[86],nLGVolumeFb*255/100
    	//timeline_restart(TLLG)
    button_event[dvtp,nButton]
        push:
    	nSelection=Get_Last(nButton)
    	switch(nSelection)
    	    case 1: // ATV
    		CALL 'LGInput' (10)
    		break
    	    case 2: // Av1
    		CALL 'LGInput' (20)
    		break
    	    case 3: // Av2
    		CALL 'LGInput' (21)
    		break
    	    case 4: // Component
    		CALL 'LGInput' (40)
    		break
    	    case 5: // VGA
    		CALL 'LGInput' (60)
    		break
    	    case 6: // HDMI1
    		CALL 'LGInput' (90)
    		break
    	    case 7: // HDMI2
    		CALL 'LGInput' (91)
    		break
    	    case 20: //Power Off
    		CALL 'LGPower' (0)
    		break
    	    case 21: //Power On
    		CALL 'LGPower' (1)
    		break
    	    case 23:// Audio Mute
    		call 'LGMute' (!nLGMuteFb)
    	    case 30:// Volume Up
    		if(nLGMuteFb=0) nLGMuteFb=1
    		nLGVolumeFb=nLGVolumeFb+2
    		if(nLGVolumeFb>=100) nLGVolumeFb=100
    		CALL 'LGVolume' (nLGVolumeFb)
    	    case 31:// Volume Dn
    		nLGVolumeFb=nLGVolumeFb-2
    		IF(nLGVolumeFb<=1 || nLGVolumeFb>100) nLGVolumeFb=0
        hold[3,REPEAT]:
    	switch(nSelection)
    		nLGVolumeFb=nLGVolumeFb+5
    	    case 31:// Volume Up
    		nLGVolumeFb=nLGVolumeFb-5
    		IF(nLGVolumeFb<=5 || nLGVolumeFb>100) nLGVolumeFb=0
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    [dvtp,nbutton[84]] = !nLGLock
    [dvtp,nbutton[23]] = !nLGMuteFb
    [dvtp,nbutton[20]] = !nLGPowerFb
    [dvtp,nbutton[21]] = nLGPowerFb
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
