Array Sorting
Hi Guys,
Does anyone know the best way, with NetLinx, to sort an Array? For example;
Sort[] = {'aaa','adc','abb','aab','acc'} = {'aaa','aab','abb','acc','adc'}
OR
Sort[] = {1,5,3,4} = {1,3,4,5}
I could attempt to write it but my life would be easier if someone has already written it
C
OR
C
DEFINE_FUNCTION fnSortAddressBook() { STACK_VAR INTEGER nSwapped STACK_VAR INTEGER nCount STACK_VAR CHAR cTempName[50] STACK_VAR CHAR cTempAddress[50] nSwapped = TRUE WHILE(nSwapped = TRUE) { nSwapped = FALSE FOR(nCount = 2; nCount <= nAddressBookEntries; nCount++) // This is = to 2 as we have no 0 in NetLinx arrays { IF(cAddressBookNames[nCount - 1] > cAddressBookNames[nCount]) { cTempName = cAddressBookNames[nCount] cTempAddress = cAddressBookAddresses[nCount] cAddressBookNames[nCount] = cAddressBookNames[nCount - 1] cAddressBookNames[nCount - 1] = cTempName cAddressBookAddresses[nCount] = cAddressBookAddresses[nCount - 1] cAddressBookAddresses[nCount - 1] = cTempAddress nSwapped = TRUE } } } }An efficient sorting algorithm can solve the problem in N logN time and a simple one can solve it N^2.
Your nRunCount variable seems to says 'I'm reinventing the wheel. The square wheel'.
You can easily implement a selection sort or an insertion sort if you can accept a quadratic execution time, otherwise a merge sort or a quicksort.
Usually in netlinx we have small arrays (length << 1000), so one of the first two algorithms is enough and very very simple to implement
http://xkcd.com/1185/
Kim has handy functions on his github - array.axi has a quicksort algorithm you could adapt for multi-dimensional arrays:
https://github.com/KimBurgess/netlinx-common-libraries
