Configure and Programming Somfy RTS Transmitter
Hi Guys,
Can any 1 help me regarding configuring and Programming the Somfy RTS Transmitter for the RTS Motors (For shades)
I have connected the RTS Transmitter to NI-700 through RS-485 Interface. But i dont see any communication happening in between control and the Transmitter.
I have loaded the TP Design file which is available in the AMX Site. But the device ( Transmitter shows offline)
Thanks in Advance Guys.. I will really Appreciate your help
I never used the AMX module (have seen too much of these modules not working well and no access to source so no way for me).
I have developped a basic module to control the RTS through RS-485 and it works perfect (control up/down and tilt). I'm working to adapt it to handle dynamically the address of the RTS connected on it (next version). You just have to pass as parameter a virtual device and the RS-424 port used and then send string to virtual with keywords used by module followed by the number of the circuit to control !
You just have to change in module the MAC Address of RTS you want to control.
Enjoy
Vincèn
Side note: never seen such crazy protocol, Somfy guys really likes to make things as difficult and non-sense as possible
Thanks everyone For your Help. We get it work through the module which was available in Third Party Devices.
thanks again
