Can a device only have one buffer message?
Trying to read/write to a file for names & numbers. I have tried creating a buffer which didn't work, and data.text clears out other messages as they come in. Never the less, this doesn't work:
BUTTON_EVENT[dcNAMES]
    PUSH:
	nCURRENT_NAME = GET_LAST(dcNAMES)
	TO[BUTTON.INPUT]
    HOLD[20]:
	SEND_COMMAND dvTP,"'@AKB-',uPRESETS[nCURRENT_NAME].cNAMES"
    RELEASE:
	WAIT_UNTIL(nDONE)
	    uPRESETS[nCURRENT_NAME].cNAMES = cDATA
	    SEND_COMMAND dvTP_VTC,"'^TXT-',ITOA(nCURRENT_NAME + 499),',0,',uPRESETS[nCURRENT_NAME].cNAMES"
	    fnWRITE_FILE('VTC Presets.csv')
BUTTON_EVENT[dcNUMBERS]
    PUSH:
	nCURRENT_NUM = GET_LAST(dcNUMBERS)
	TO[BUTTON.INPUT]
    HOLD[20]:
	SEND_COMMAND dvTP,"'@AKP-',ITOA(uPRESETS[nCURRENT_NUM].nNUMBERS)"
    RELEASE:
	WAIT_UNTIL(nDONE)
	    uPRESETS[nCURRENT_NUM].nNUMBERS = nDATA
	    SEND_COMMAND dvTP_VTC, "'^TXT-',ITOA(nCURRENT_NUM + 603),',0,',uPRESETS[nCURRENT_NUM].nNUMBERS"
How can I hold a value in one buffer without clearing the other? Is this possible?
    You can put the get_last statement in both the Hold and release events too.
    Not sure what you are trying to do here, but I would strongly advise against using wait_until in a button event. Its not incorrect but can lead to some difficult to find bugs. Having written AMX code for 10 years, I've never used it once, nor needed to.
  • mjones2620mjones2620 Posts: 86
    ericmedley wrote: »
    Ahhh, this worked. THANKS!
    a_riot42 wrote: »
    I'm parsing the message in the keyboard/keypad and I don't want it to write to file until after the message is parsed. Putting the Get_last in my release statement worked.
    This was code tweaked from my P2 class... they tought us WAIT_UNTIL. I kind of like it.
    mjones2620 wrote: »
    I would agree with a_riot42. If you are parsing for a data string from a UI upon keypad/keyboard entry, I'd probably initiate it in the data_event and then call a function. For example: what happens if the user hits abort on the keypad? Or the panel goes offline? Stuff like that...
    I'm glad the fix worked. :)
    ericmedley wrote: »
    If user hits abort I am using the CANCEL_ALL_WAITS function.
    mjones2620 wrote: »
    I wouldn't recommend that. What if you need a wait elsewhere that shouldn't be affected? And what if one gets added 6 months from now, and you forget the cancel_all is in there?
    mjones2620 wrote: »
    Cancel_all_waits and wait_until should be forgotten and never used. As soon as you think you need them to make something work you should throw out what you've written, get a good night's sleep and start from scratch in the morning. :)
    If you're trying to use a single data event handler to process multiple devs you could do something like this for populating and processing your buffers:
    DEFINE_DEVICE
    dvDevice_1	= 5001:1:0;
    dvDevice_2	= 5001:2:0;
    dvDevice_3	= 5001:3:0;
    DEFINE_CONSTANT
    NUM_DEVs 	= 3;
    DEV dvDev_Arry[NUM_DEVs]=
          dvDevice_1
         ,dvDevice_2
         ,dvDevice_3
    DEFINE_VARIABLE
    CHAR cDev_Buffers[NUM_DEVs][2048];
    DATA_EVENT[dvDev_Arry]
         ONLINE:
    	  //initialize devs
         STRING:
    	  STACK_VAR INTEGER nIndx;
    	  nIndx = GET_LAST(dvDev_Arry);
    	  cDev_Buffers[nIndx] = "cDev_Buffers[nIndx],DATA.TEXT";
    	  if(find_string(cDev_Buffers[nIndx],"$0D,$0A",1))
    	       //pass the index to the parsing function so you know which dev you're processing
    	       fnParseBuffer(nIndx,REMOVE_STRING(cDev_Buffers[nIndx],"$0D,$0A",1));
