IP Control Over DXLink
I need to control a display by IP, I have done it often directly from a master. But this time doing it over DXLink HDMI RX, I am going to set receiver to IP pass thru. Question is do I define the IP port in DEFINE DEVICE for the display the same way as I would for standard IP control i.e. dvLCD_1 = 0:6:0
I am sure it is in a manual somewhere but need to get this job knocked out.
Thanks for your time
Michael
  • nickmnickm Posts: 152
    You are correct. You create a standard socket just as you would if the display was connected back to the master through a switch as opposed to the DSLink.
  • huttencmhuttencm Posts: 23
    Thanks one less thing to worry about :)
