SRC password
                    Hi all,
One quick question.
I downloaded SRC file from NI-3100 and when I extracted it, but it has a password.
Do I have an option to by pass the password and extract src file and edit it.
and can I upload a new SRC file even if the current SRC file is password protected.
Thanks in advance.
                One quick question.
Thanks in advance.
The 2 main ways to get into a protected zip are:
1) Get the original author or someone at their company to tell you the password. (Social engineering)
2) Guess the correct password, usually done via a program that uses a dictionary or just tries every possibility.
Usually option 1 is easier, and the legality of option #2 is questionable.
However, if all else fails: Since you were able to connect to pull the old program out, you should be able to just replace the program entirely with a new creation of your own.
I had the same thing on Friday. Company long out of business, my customer buys a Motor coach with AMX on board. Trying to track down original programmer for password. Good luck to you!
Yes. Exactly.
There have been too many times when I was forced to add "just this one change" to someone else's ancient job, and even though the one little bit I added worked as requested - I still ended up wasting hours when the end user essentially re-tested the entire job and expected me to "fix" other code that never worked in the first place.
"These are not the droids we seek. Let them pass..."
