FTP from Master to server
Hi there,
Hope someone can help me, this is my first time posting on the forum and I know this topic has been discussed often. But I need help with the sending of a file that is on a master to the server.
I am connecting to the server from the master via FTP, so connection is fine. I am converting the data to xml and writing it to a file on the master and that is all OK.
_____________________________________________________________________________
DEFINE_FUNCTION fnWRITE ()
LOCAL_VAR SLONG HFile
LOCAL_VAR SLONG nBytes
LOCAL_VAR CHAR fBUF[100]
HFile = FILE_OPEN('Temp_TMprobe.XML',2)
if(HFile>0)
fBUF = cXML_String
nBytes = FILE_WRITE(HFile,fBUF,LENGTH_STRING(fBUF))
SEND_STRING 0,'SUCCESS'
FILE_CLOSE(HFile)
ELSE
SEND_STRING 0,"'BAD FILE OPENING',ITOA(HFILE)"
__________________________________________________________________________________________
To send the file to the server one would use something like the following command:
Send_String dvWebDataTx,"'STOR Temp_TMprobe.XML',$0D,$0A"
when this command is sent it just creates a file on the server with the name Temp_TMprobe.xml and obviously does not extract the file from the master to be sent.
How do I get the actual file from the master to the send command.
Your help will be appreciated.
Wim
if(HFile>0)
fBUF = cXML_String
FILE_CLOSE(HFile)
ELSE
Wim
AMX has a solution for this...
http://www.amx.com/products/i!-FTPSender.asp
Thanks for the reply,
I found the product on the AMX site. I'm working trough it to see how it must be done.
