Bring back ^BMF
mush
Why???
Is anybody as frustrated as I am that AMX have removed the ^BMF command from G5 touch panels?
It makes no sense. Take a RMS-type schedule interface for instance. It has 96 slots (24 hours at 15 min intervals). Each slot needs to be shown/hidden, have some text added if needed and background colour changed for adjacent meetings. Instead of 96 commands to each panel I now have to send nearly 300. How is that going to ever make my system more efficient?
Simon
Simon
In fact, I think BMF is an inside joke.
Big
Mother
F***er
I use the BMF command a lot and not having it or some equivalent would be pretty awful.
The G5 platform gives us options for new functionality that were simply impossible in G4. You can expect many powerful new features in future releases. However, expecting older ways of doing things to be added back in will likely prove fruitless. So for now my advice is pretty simple. If you absolutely cannot migrate away from G3/G4 commands that have been obsoleted then stick with the G4 series panels.
As always, you should communicate requests to restore commands to tech support who will involve product management.
The BMP command is for assigning a picture to a button.
[CMDERROR:^BCT-1,0,Green]
[CMDERROR:^BCT-1,0,00000000]
[CMDERROR:^BCT-1,0,12]
I tried '^BMF-1,0,%CF Green' with no luck so ended up having to make multi-state buttons and use ^ANI to go to the desired colour, I enjoyed wasting 4 hours on that, then I discovered that if you do a page flip at the same time as triggering an animation it doesn't work, another hour modifying my code to delay page flips.
Tell tech support so they can throw it into the suggestion bin with the complaints about Duet modules.
I'm happy to continue this rant any time.
I don't know, you could pack a lot of information into a BMF command which saved commands. I used it for that reason alone. Perhaps the newer panels can handle more commands efficiently so it isn't an issue, but there should be a way to encode a lot of properties in one general command, rather than every property requiring its own command. If I want to set up a button with text, color, font, bitmap, blah, blah, blah, doing it with one command is awfully convenient.
that would be better than BMF anyways no?
I would advocate something I have done in the past be used in a more integrated fashion to the development environment (perhaps an include lib). Others may have done this too, but I had built a pre-defined structure that simply housed all of the available button params. Just call a function to clear said structure, then define the params you wish to set (compiler helps after structure is compiled first time - e.g. "Button_Parm." and a list of available params shows up based on struct definition) and then call a function to embed values that have an assignment into a ^BMF command and shoot it to a particular button or range... Just a thought.
Is this possible, or is it in already and I've just not seen it. I wanted to set the panel time to suit my masters, but you can't without doing a an SSH session
Thank you AMX!
