Autopatch 1YDM? Newbie
Hello - I'm coming from an Extron switcher which was working without a hitch until it went belly up (tested RS232 - works). I got an Autopatch 1YDM via ebay (RGBHV) and have tried using the same code but just changing the protocol for the Autopatch which doesn't seem to work. I'm not sure if it's my code or the cable (NULL) that I am having an issue with.
Sample Code:
Original Extron:
PUSH [TOUCH_PANEL, 69] (* BUTTON 69 WAS PRESSED ON TOUCH_PANEL *)
SEND_COMMAND PANA_ST50, "'SP', COMPONENT_1"
SEND_STRING MATRIX,"'5*1!',$0D" (* CAMERA FRONT DOOR , COMPONENT 2 FAMILY RM*)
Adjusted code:
SEND_STRING MATRIX,"'CL1I5O1T'" (* CAMERA FRONT DOOR , COMPONENT 2 FAMILY RM*)
Any help would be much appreciated.
Thank You
Sample Code:
Original Extron:
Adjusted code:
Thank You
DATA_EVENT[MATRIX]
ONLINE:
SEND_COMMAND MATRIX, 'SET BAUD 9600,N,8,1 485 DISABLE'
To create a switch: CL#I#O#T or CL#O#I#T
Should be:
SEND_STRING MATRIX,"'CL0I5O1T'" (* CAMERA FRONT DOOR , COMPONENT 2 FAMILY RM*)
to route Audio and Video
CL0 - Audio and Video
CL1 - Video Only
CL2 - Audio Only
