Benq MX850UST Control
Cedric
Hi,
I'm trying to control from RS232 a Benq MX850UST
On the RS232 control documentation from Benq
- Baud Rate Default in 115200 bps
- Data Length 8 bit
- Parity Check None
- Stop Bit 1 bit
- Flow Control None
Power ON ASCII command : *pow=on#
the code is :
dvProj_RS232 = 5001:1:0
DATA_EVENT[dvProj_RS232]
online:
send_command data.device,'SET BAUD 115200,N,8,1 485 DISABLE'
SEND_STRING dvProj_RS232,"*pow=on#"
I had try the different hexa command on the forum, but doesn't seem to work.
If anyone have any suggestion or any other protocol, thanks.
- Data Length 8 bit
- Parity Check None
- Stop Bit 1 bit
- Flow Control None
the code is :
online:
Should be
SEND_STRING dvProj_RS232,'*pow=on#'
Thanks, had try both in fact (with single and double quote)
I just receive a file from benq with all the rs232 general protocol, if someone need this file, just contact me.
Also on this file for the power on the ASCII command is :
<CR>*pow=on#<CR> so
SEND_STRING dvProj_RS232,'<CR>*pow=on#<CR>'
and on Hexa:
SEND_STRING dvProj_RS232,"$0D,$2A,$70,$6F,$77,$3D,$6F,$6E,$23,$0D"
Steel not working
I will try to make an other rs232 cable, just to be sure, had take one already made.
So, you have to make a hybrid string
SEND_STRING dvProj_RS232,"$0d,'*pow=on#',$0d"
They really should have covered this in Programmer 1 class.
the problem was coming from the wire
The one I was using for the test was working on other device but not the benq
Had to make a ''special one'' for this connection
Master -- Benq
1--1
2--3
3--2
4--4
5--5
6--6
7--7
8--8
9--9
on the other cable only RX TX and GnD are connect
Now it's working can turn on/off from ASCII or hex
Thanks for your help
