Intercept Java Module Strings
Hi,
I am using an Extron Crosspoint switcher that sends RS232 over XTP (cat cable) to Extron receivers that then pass the RS232 commands to a device. From reading the documentation and talking with tech support. It seems that you have to create a telnet session to the Crosspoint on a specific Port (the Port corresponds to the Output Port that the RS232 command will get sent on), then everything that you enter in the telnet session will be passed as an RS232 command.
So what I'm trying to do is use Java Modules to handle creating the strings for the commands, but I'm trying to figure out how I can PULSE a Channel on the Java Virtual Device, and instead of having it send the string to a physical device. I will Intercept that string, and create a telnet session to the Crosspoint and then send the string to it, and hopefully whatever I receive from the telnet session, I would want to pass back to the Java Module to process and activate appropriate channels for feedback.
Does anyone know how to accomplish this? or maybe a better way of doing it?
Javed
Javed
My understanding on passing rs232 on XTP crosspoint is to configure first the port on the switcher and assigned that port to its corresponding output, its like you are passing through a DTP Transmitter to DTP receiver, If TS says that you have to build a telnet session, the easiest way it to use IP_Client communication.
I tried this, I had created 2 devices
vdvDisplay 41001:1:0 // this is the java virtual device
vdvDisplayCatcher 33001:1:0 // this is to replace thy physical device
Then I did this
DEFINE_MODULE 'Some_Module_Name' comm(vdvDisplay, vdvDisplayCatcher)
and
DATA_EVENT [vdvDisplayCatcher]
STRING:
SEND_STRING 0,"DATA.TEXT"
COMMAND:
I thought this would catch the strings coming out of the Java module that were supposed to go to the physical device, but this never fired.
When I watched the Notification window, I would see it report that String To: 33001:1:0 [Some string] and String From: 33001:1:0 [Some string], but it would never print to the diagnostics window
I even tried adding PASSBACK-1 on the Java module, but still didn't get those data events to fire.
Am I doing something wrong here?
Thanks for the input,
Javed
define_function sendXTPCPString (char swString[100])
if (!SwitchOnline)
ip_client_open (dvXTPSwitch, 'device ip address', 23, ip_tcp)
wait_until (SwitchOnline)
send_string dvXTPSwitch_1, swString
else if (SwitchOnline)
send_string dvXTPSwitch, swString
I tried changing it to 33001:1:1, but it still didn't work. I am probably just going use direct IP connections to the devices and keep them open. Since I can't get this to work.
Thanks for everyone for the input.
Javed
