Cisco MX300 Codec
Hi,
Do anyone know the MX300 control command and C40 control command is it different? Currently I am using AMX control system to control the Cisco MX300 via LAN. There have another room using C40 codec, the program is done and function well. So I just duplicate the program to this room control the MX300. I notice that some function is not working well. Example : I cannot hang up the call from AMX touch panel. The command is function well on C40 codec.
Do anyone have this experience?
  • Use the SX20 module, that is actually buried in the MX300. I'd create a separate user for AMX, and you will need to make sure that telnet is enabled. Good luck!
  • Thanks ... I will try it :)
