Get_Last Panel # to a variable...
Hi there,
I am hoping to convert a Get_Last panel number to a variable to be used within a Define_Call but cannot seem to get it right..
I am using Get_Last to carry out page flips etc. on the panel that initiates the button press but want to then take
the Get_Last value and store it in a variable to be used within the Define_Call..
So effectively if 10010:1:1 presses the button the page-flipping within the Case 1: below gets carried out on 10010 for all steps within the Call, based on a variable..
What I am trying to do is to lock the TP number down to all actions within the Define_Call so that if someone
initiates another button press in the same room, it doesn't get confused..
Is there a way of writing something like...
cTempPanelNo = dvTP_Kitchen[nDeviceKitchen].NUMBER
and then SEND_COMMAND cTempPanelNo:1:0, "'Blah Blah.....'"
I have tried what I am capable of and keep getting dimension mismatch and array errors...
BUTTON_EVENT [dvTP_Kitchen,BUTTON.INPUT.CHANNEL]
PUSH:
nDeviceKitchen = GET_LAST(dvTP_Kitchen);
SWITCH(BUTTON.INPUT.CHANNEL)
CASE 1: CALL 'KITCHEN WATCH SKY1'
CASE 2: CALL 'KITCHEN WATCH FREEVIEW'
CASE 3: CALL 'KITCHEN WATCH LOUNGE BD'
CASE 4: CALL 'KITCHEN WATCH ROKU'
CASE 6: CALL 'KITCHEN AIRPLAY'
CASE 7: CALL 'KITCHEN MUSIC SERVER 1'
CASE 8: CALL 'KITCHEN MUSIC SERVER 2'
CASE 9: CALL 'KITCHEN RADIO'
CASE 10: CALL 'KITCHEN WATCH CINEMA BD'
CASE 11: CALL 'KITCHEN WATCH BEDROOM BD'
CASE 13: CALL 'KITCHEN WATCH CCTV'
CASE 20: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'@PPN-Shutdown_Kitchen'"
CASE 21: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'PAGE-Src_Kitchen_1'"
CASE 22: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'PAGE-Src_Kitchen_2'"
CASE 23: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'PAGE-Src_Kitchen_3'"
CASE 24: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'PAGE-Src_Kitchen_4'"
CASE 98: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'@PPN-Lighting_Kitchen'"
CASE 99: SEND_COMMAND dvTP_Kitchen[nDeviceKitchen].NUMBER:1:0,"'@PPN-Shutdown_Kitchen'"
CASE 100: CALL 'TURN KITCHEN OFF'
Then you can do the switch case there.
the way I will do it is creating a device for the GUI logic. using function to process you page logic (switch,case,send_command
As I understand it you are just trying to get the device number from the index that triggered the event? In your define call just specify a DEV type parameter and pass it dvTP_Kitchen[nDeviceKitchen].
DEFINE_CONSTANT DEV dvTP_AllPanels[] = { dvTP_Kitchen1, dvTP_Kitchen2, dvTP_FamilyRoom, dvTP_Bedroom // etc... } KITCHEN_PANEL1 = 1 KITCHEN_PANEL2 = 2 FAMILY_PANEL = 3 BED_PANEL = 4 // Code driven flips for all rooms Integer nMenuButtons[] = { 20, 21, 22, 23, 24, 98, 99 } Char cMenuFlips[][][80] = { { // KITCHEN_PANEL1 {"'@PPN-Shutdown_Kitchen'"}, {"'PAGE-Src_Kitchen_1'"}, {"'PAGE-Src_Kitchen_2'"}, {"'PAGE-Src_Kitchen_3'"}, {"'PAGE-Src_Kitchen_4'"}, {"'@PPN-Lighting_Kitchen'"}, {"'@PPN-Shutdown_Kitchen'"} }, { // KITCHEN_PANEL2 {"'@PPN-Shutdown_Kitchen'"}, {"'PAGE-Src_Kitchen_1'"}, {"'PAGE-Src_Kitchen_2'"}, {"'PAGE-Src_Kitchen_3'"}, {"'PAGE-Src_Kitchen_4'"}, {"'@PPN-Lighting_Kitchen'"}, {"'@PPN-Shutdown_Kitchen'"} }, { // FAMILY_PANEL {"'@PPN-Shutdown_Family'"}, {"'PAGE-Src_Family_1'"}, {"'PAGE-Src_Family_2'"}, {"'PAGE-Src_Family_3'"}, {"'PAGE-Src_Family_4'"}, {"'@PPN-Lighting_Family'"}, {"'@PPN-Shutdown_Family'"} }, { // BED_PANEL {"'@PPN-Shutdown_Bed'"}, {"'PAGE-Src_Bed_1'"}, {"'PAGE-Src_Bed_2'"}, {"'PAGE-Src_Bed_3'"}, {"'PAGE-Src_Bed_4'"}, {"'@PPN-Lighting_Bed'"}, {"'@PPN-Shutdown_Bed'"} } } DEFINE_VARIABLE Integer nCurrentPanelSource[4] // I'd break out the define calls like this... // (I'd also use functions instead, but it doesn't look much different) DEFINE_CALL 'WATCH' (Integer nWhichPanel, Char cFunction[]) { Switch(nWhichPanel) { Case KITCHEN_PANEL1: Case KITCHEN_PANEL2: // for panels in the same area, stack the cases { Switch cFunction { Case 'SKY1': { //Init Sky1 in the kitchen } // etc... } } Case FAMILY_PANEL: { Switch cFunction { Case 'SKY1': { //Init Sky1 in the family room } // etc... } } Case BED_PANEL: { // etc... } } } // Similar to above DEFINE_CALL 'LISTEN' (Integer nWhichPanel, Char cFunction[]) {} DEFINE_CALL 'ROOM OFF' (Integer nWhichPanel) {} DEFINE_EVENT // Panel navigation (created by moving the button numbers into the integer array above) BUTTON_EVENT[dvTP_AllPanels,nMenuButtons] { Push: { Stack_Var Integer nRoom Stack_Var Integer nMenuBtn nRoom = Get_Last(dvTP_AllPanels) nMenuBtn = Get_Last(nMenuButtons) Send_Command dvTP_AllPanels[nRoom],"cMenuFlips[nRoom][nMenuBtn]" } } // Source select buttons // (I would define an integer array of the specific buttons for this also) BUTTON_EVENT [dvTP_AllPanels,BUTTON.INPUT.CHANNEL] { PUSH: { Stack_Var Integer nRoom nRoom = GET_LAST(dvTP_AllPanels) // Can use something like this for source tracking nCurrentPanelSource[nRoom] = BUTTON.INPUT.CHANNEL SWITCH(BUTTON.INPUT.CHANNEL) { CASE 1: CALL 'WATCH' (nRoom, 'SKY1') CASE 2: CALL 'WATCH' (nRoom, 'FREEVIEW') CASE 3: CALL 'WATCH' (nRoom, 'LOUNGE BD') CASE 4: CALL 'WATCH' (nRoom, 'ROKU') CASE 6: CALL 'LISTEN' (nRoom, 'AIRPLAY') CASE 7: CALL 'LISTEN' (nRoom, 'MUSIC SERVER 1') CASE 8: CALL 'LISTEN' (nRoom, 'MUSIC SERVER 2') CASE 9: CALL 'LISTEN' (nRoom, 'RADIO') CASE 10: CALL 'WATCH' (nRoom, 'CINEMA BD') CASE 11: CALL 'WATCH' (nRoom, 'BEDROOM BD') CASE 13: CALL 'WATCH' (nRoom, 'CCTV') CASE 100: CALL 'ROOM OFF' (nRoom) } } }Paul
Its working well - BUT - I am waiting for two panels that have chosen the same zone to have a problem eventually when two calls are called and the Get_Last panel number changes half way through the call.
This is the reason I was trying to convert my Dev no to a variable and then keep sending the different steps of the get call to the Panel number that was converted at the beginning of the call so to speak.
Greg, I will go through this in detail to see if I can convert my code... The include for all of these panels is 5k lines long so it could be a nightmare but I desperately want to do this the right way and get better at doing this
DEFINE_CONSTANT Integer nSourceSelectButtons[] = { 100, // OFF - Made this the first item in the array, you'll see why below 1, // 'SKY1' 2, // 'FREEVIEW' 3, // 'LOUNGE BD' 4, // 'ROKU' 6, // 'AIRPLAY' 7, // 'MUSIC SERVER 1' 8, // 'MUSIC SERVER 2' 9, // 'RADIO' 10, // 'CINEMA BD' 11, // 'BEDROOM BD' 13 // 'CCTV' } DEFINE_EVENT BUTTON_EVENT [dvTP_AllPanels,nSourceSelectButtons] { PUSH: { Stack_Var Integer nRoom nRoom = GET_LAST(dvTP_AllPanels) nCurrentPanelSource[nRoom] = GET_LAST(nSourceSelectButtons)-1 // NOTE, I subtracted 1 here // The cases are now in sequence based on the array order, not the button numbers SWITCH(nCurrentPanelSource[nRoom]) { CASE 0: CALL 'ROOM OFF' (nRoom) // Since I subtracted 1 above, Off is now 0 CASE 1: CALL 'WATCH' (nRoom, 'SKY1') CASE 2: CALL 'WATCH' (nRoom, 'FREEVIEW') CASE 3: CALL 'WATCH' (nRoom, 'LOUNGE BD') CASE 4: CALL 'WATCH' (nRoom, 'ROKU') CASE 5: CALL 'LISTEN' (nRoom, 'AIRPLAY') CASE 6: CALL 'LISTEN' (nRoom, 'MUSIC SERVER 1') CASE 7: CALL 'LISTEN' (nRoom, 'MUSIC SERVER 2') CASE 8: CALL 'LISTEN' (nRoom, 'RADIO') CASE 9: CALL 'WATCH' (nRoom, 'CINEMA BD') CASE 10: CALL 'WATCH' (nRoom, 'BEDROOM BD') CASE 11: CALL 'WATCH' (nRoom, 'CCTV') } } }A trick I sometimes use is putting the off button first and subtracting 1 from get_last() so that off's value is 0.You can use that like a usage flag... any value >0 means we are "in use".
