Duet Module Warming State didn't goes Off
Hi all,
i'm currently working on a project and i'm having a strange issue.
I'm currently using channel_event[vdvDisplay,Warming] to know when the warming state switch from ON/OFF. at the same time i have enable counternofity-1 to know when warming-xx reach 0 and the warming state stay active. I didn't have this issue with the cooling state. any one have a clue for me.
Here's the part of the Data_event for my virtual device
Here's the part of the channel event
i have commented some line during my test to understand why it doesn't work.
Thanks folk for your help.
COMMAND:
// local variables
STACK_VAR CHAR cCmd[DUET_MAX_CMD_LEN]
STACK_VAR CHAR cHeader[DUET_MAX_HDR_LEN]
STACK_VAR CHAR cParameter[DUET_MAX_PARAM_LEN]
STACK_VAR INTEGER nParameter
//STACK_VAR CHAR cTrash[20]
cCmd = DATA.TEXT
send_string 0,data.text
cHeader = DuetParseCmdHeader(cCmd)
switch(cHeader)
CASE 'COOLDOWN':
TDisplay.ncoolingtime = atoi(DuetParseCmdParam(cCmd))
//fnSendCommand(dvTPMain,"'^BMF-1,0,%GH',itoa(TDisplay.ncoolingtime),'%GL0'") // Set level range of TP
CASE 'WARMUP':
TDisplay.nwarmingtime = atoi(DuetParseCmdParam(cCmd))
//fnSendCommand(dvTPMain,"'^BMF-2,0,%GH',itoa(TDisplay.nwarmingtime),'%GL0'") // Set Level range of TP
CASE 'COOLING':
nParameter = atoi(DuetParseCmdParam(cCmd))
if(nParameter=False) TDisplay.ncooling=false else TDisplay.ncooling=true
TDisplay.nwaitingtimer = nParameter*255/TDisplay.ncoolingtime
fnSendLevel(dvTPMain,display_waitlvl,TDisplay.nwaitingtimer)
CASE 'WARMING':
TDisplay.nwarming=false
//fnSendCommand(vdvDisplay,'INPUTSELECT-6')
else
TDisplay.nwarming=true
TDisplay.nwaitingtimer = nParameter*255/TDisplay.nwarmingtime
CASE 'INPUTSELECT':
TDisplay.ninput = nParameter
channel_event[vdvDisplay,display_cooling] // Display Cooling
on:
//TDisplay.ncooling=true
fnSendString(0,'Display Cooling')
off:
//TDisplay.ncooling=false
fnSendString(0,'Display Cooling Complete')
channel_event[vdvDisplay,display_warming] // Display Warming
on:
//TDisplay.nwarming=true
fnSendString(0,'Display Warming')
off:
//Tdisplay.nwarming=false
//send_command vdvDisplay,'INPUTSELECT-6'
fnSendString(0,'Display Warming Complete')
What do you get back in terms of the feedback channels? Is 253 (SNAPI warming) going OFF or staying on? If telnet shows that it is going OFF, then it is netlinx code related. If it never goes off, then it is pointing towards a module problem.
To test your code, can you emulate the channel event through studio? If so, does that fire your send_string 0?
can I telnet the processor yo get the state of a vdevice?
I was only using emulate/control in studio
to troubleshoot.
if I reinit the module when the warming countdown is complete, everything goes fine.
right now I'm using the duet module of an NEC np600 projector because it's the device I have with me.
Welcome to NetLinx v4.1.373 Copyright AMX LLC 2012 >device status 10005:1 Device Status ------------- Device 10005 AMX LLC,MXT-700i,v2.104.54 contains 3 Ports. Port 1 - Channels:255 Levels:8 MaxStringLen=1024 Types=8 bit MaxCommandLen=1024 Types=8 bit The following input channels are on:None The following output channels are on:None The following feedback channels are on:None Level 1=0 Supported data types=UByte,UInt Level 2=0 Supported data types=UByte,UInt Level 3=0 Supported data types=UByte,UInt Level 4=0 Supported data types=UByte,UInt Level 5=0 Supported data types=UByte,UInt Level 6=0 Supported data types=UByte,UInt Level 7=0 Supported data types=UByte,UInt Level 8=0 Supported data types=UByte,UIntcan i do the same thing with the web application in the processor under diagnostics ?
PROGRAM_NAME='test' (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 04/05/2006 AT: 09:00:25 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) include 'SNAPI.axi' (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE dvCom1 = 5001:1:0 // ComPort A (*** Virtual Device Duet Module ***) vdvDisplay = 41001:1:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT TRUE = 1 FALSE = 0 DISPLAY_WARMING = 253 DISPLAY_COOLING = 254 DISPLAY_POWER = 255 DISPLAY_ONLINE = 251 DISPLAY_READY = 252 // Initialized DISPLAY_ON = 27 DISPLAY_OFF = 28 DISPLAY_HDMI = 6 //InputSelect Value (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE structure _DeviceState // Device State variable { integer ninitialize // Initialize State integer nonline // Online State integer npower // Power State integer nwarming // Warming State integer ncooling // Cooling State integer nwarmingtime // Warming Time Value integer ncoolingtime // Cooling time Value integer nwaitingtimer // Timer value during warming || cooling state integer nready // Ready to operate state integer nInput // Actual Input Selected integer nInputreq // Requested Input } (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE _DeviceState TDisplay // Display Device State (***********************************************************) (* LATCHING DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_LATCHING (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) Define_Function fnSendString(Dev Device, Char Cmd[]) // Send String to a Device { Send_String Device, Cmd; } (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START DEFINE_MODULE 'NEC_NP610_Comm_dr1_0_0' comm1(vdvDisplay, dvCom1) (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT DATA_EVENT[vdvDisplay] { ONLINE: { SEND_COMMAND vdvDisplay,'Baud_Rate,19200' SEND_COMMAND vdvDisplay,'PROPERTY-Poll_Time,5000' SEND_COMMAND vdvDisplay,'REINIT' SEND_COMMAND vdvDisplay,'COUNTERNOTIFY-1' SEND_COMMAND vdvDisplay,'?COOLDOWN' SEND_COMMAND vdvDisplay,'?WARMUP' } STRING: { send_string 0,"vdvDisplay.NUMBER,' String: ',data.text" } COMMAND: { // local variables STACK_VAR CHAR cCmd[DUET_MAX_CMD_LEN] STACK_VAR CHAR cHeader[DUET_MAX_HDR_LEN] STACK_VAR CHAR cParameter[DUET_MAX_PARAM_LEN] STACK_VAR INTEGER nParameter //STACK_VAR CHAR cTrash[20] cCmd = DATA.TEXT send_string 0,data.text cHeader = DuetParseCmdHeader(cCmd) switch(cHeader) { CASE 'COOLDOWN': { TDisplay.ncoolingtime = atoi(DuetParseCmdParam(cCmd)) //fnSendCommand(dvTPMain,"'^BMF-1,0,%GH',itoa(TDisplay.ncoolingtime),'%GL0'") // Set level range of TP } CASE 'WARMUP': { TDisplay.nwarmingtime = atoi(DuetParseCmdParam(cCmd)) //fnSendCommand(dvTPMain,"'^BMF-2,0,%GH',itoa(TDisplay.nwarmingtime),'%GL0'") // Set Level range of TP } CASE 'COOLING': { nParameter = atoi(DuetParseCmdParam(cCmd)) //if(nParameter=False) TDisplay.ncooling=false else TDisplay.ncooling=true TDisplay.nwaitingtimer = nParameter//*255/TDisplay.ncoolingtime //fnSendLevel(dvTPMain,display_waitlvl,TDisplay.nwaitingtimer) } CASE 'WARMING': { nParameter = atoi(DuetParseCmdParam(cCmd)) TDisplay.nwaitingtimer = nParameter//*255/TDisplay.nwarmingtime //fnSendLevel(dvTPMain,display_waitlvl,TDisplay.nwaitingtimer) } CASE 'INPUTSELECT': { nParameter = atoi(DuetParseCmdParam(cCmd)) TDisplay.ninput = nParameter } } } } channel_event[vdvDisplay,display_cooling] // Display Cooling { on: { TDisplay.ncooling=true fnSendString(0,'Display Cooling') } off: { TDisplay.ncooling=false fnSendString(0,'Display Cooling Complete') } } channel_event[vdvDisplay,display_warming] // Display Warming { on: { TDisplay.nwarming=true fnSendString(0,'Display Warming') } off: { Tdisplay.nwarming=false //send_command vdvDisplay,'INPUTSELECT-6' fnSendString(0,'Display Warming Complete') } } channel_event[vdvDisplay,display_ready] // display Initialized State { on: { TDisplay.ninitialize=true } off: { TDisplay.ninitialize=false } } channel_event[vdvDisplay,display_online] // display Online State { on: { TDisplay.nonline=true } off: { TDisplay.nonline=false } } channel_event[vdvDisplay,display_power] // Display Power State { on: { TDisplay.npower=true } off: { TDisplay.npower=false } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)i copy what i have monitor with mange system web browser
My guess is that given the mixed results you are receiving, it could be a problem with the module not understanding the response from the device. If you telnet into the processor again, you can do the following to try and further diagnose the issue on your own:
and observe the parsing of responses and how/if/why it is breaking down.
if i passthru the command send after the countdown is complete the projector response me and the warming state going away.
Good AM Raphael,
Try using 91; it is probably a logic error...
90 is the min value.
Let me know if this works.
Control is IP or RS232?
If RS232 monitor the strings to and from the projector to see if it is actually using feedback.
If IP, use WireShark...
If they are faking the feedback; it could still be a logic issue.
Doesn't help if it is a logic module, but you could create your on Fake feedback to handle this.
Or create your own module... a bit of work.
i would probably using that alternative with a timeline after the countdown is finnish and kill this timeline when the warming state will goes low.
the magic of writing code
Are you doing a lot of AMX in Montreal?
It seems most of the new jobs in Calgary are Cre$tron.
Shell is moving everything to Cre$tron over the next 2 years.
I have to go back out to TO in Oct/Nov to do Cre$tron P201.
Completed PII, and submitted the Project for "marking" and have not heard back...
Did you do PIII?
