Channel_event. Off for all channel
                    Hello!
I have the following code:
Integer SourceBtn[] = {11,12,13,14}
channel_event [dvRemote, SourceBtn[] {
On : {switch (channel.channel){
case 11 : do something
Case 12: do something
Etc.}}
Off: {switch (channel.channel){
case 11:
Case 12:
Ets.}}
How can I perform the necessary action to me, only when all channels are switched off in this array?
Etc.}}
case 11:
Case 12:
Ets.}}
CHANNEL_EVENT [dvRemote,SourceBtn] { ON : { } OFF : { IF(![dvRemote,SourceBtn[1]] && ![dvRemote,SourceBtn[2]] && ![dvRemote,SourceBtn[4]] && ![dvRemote,SourceBtn[4]]) { // do something } } }How are you handling OFF or source=0? Tracking the currently selected source (including OFF) would be cleaner for panel button feedback.
I think we need to know more about the scenario than you have provided in the original post. Based on what I think you are doing, this is the approach I would use.
DEFINE_DEVICE dvRemoteZone1 = 10001:1:0 DEFINE_CONSTANT INTEGER nNumAVZones = 1 INTEGER nTPBtn_SourceSelect[] = { 10, //OFF 11, //Source 1 12, //Source 2 13, //Source 3 14 //Source 4 } DEV dvRemoteControls [] = { dvRemoteZone1 } DEFINE_VARIABLE INTEGER nCurrentSource [nNumAVZones] //track who is doing what - suggest using a structure and capture more info on the zone, but this is a quick example. DEFINE_EVENT BUTTON_EVENT [dvRemoteControls, nTPBtn_SourceSelect] //using the array instead of a single remote - project could grow and this is approach is easier to maintain { PUSH: { SWITCH (GET_LAST(nTPBtn_SourceSelect)) { CASE 1: {do something} //Zone Off CASE 2: {do something} //Source 1 } //Update Tracking (would be fake and suggest getting it from the switcher feedback) nCurrentSource [GET_LAST(dvRemoteControls)] = GET_LAST(nTPBtn_SourceSelect) } }and to disable all I perform total_off ... and as soon as all the channels is disabled, you need to send a shutdown command to the devices) bad idea?
If the project requirement has you acting on channel feedback, then Nick has provided an answer that will work for your needs. For me, I still need more information because I find the question to be out of context, and the additional details would aid me in providing a better and more complete answer.
Maybe others can chime in.
