ELO NEW 22-inch Desktop touchpanel driver 2201L
I tryed ELO 22 touchpanel 2201L(zero bezel type) using USB , but TPI-PRO-DVI doesn't work.
Select ELO touch /ELO19 touch Driver, both doesn't work.
One previous model 2200L using USB/serial works TPI-PRO-DVI without problems.
Touch driver has changed ? specification shows IntelliTouch -> IntelliTouch Plus.
Is there someone success ELO 2201L on TPI-PRO-DVI ?
  • JasonSJasonS Posts: 229
    Driver selection is only for serial touch panels. There are several versions of firmware that are specific for the Elo panels. It can be a pain to get them to work. Tech support suggests disconnecting the Elo USB, updating firmware, and after TPI reboots pluging USB back in. Another thing that I have occasionally had to do with Touch Screens of multiple brands, is connect it to a computer first, get it working there and then it will work with the TPI.
  • koozookoozoo Posts: 17
    thanks for advice
    Newest touchdriver which download from AMX web site, suite 22 ELO touchpanel using USB.
    ET2201L-8UWA-0-MT-GY-G IntelliTouch Plus OK
    ET2201L-8UWA-0-ZB-GY-G iTouch NG
    ET2201L-2UWA-0-MT-GY-G Projected Capacitive NOT tried
