Cisco C Series IP Control
I am getting ready to control a CISCO C40 codec via IP. Another programmer said that there is a special hex string I need to send in order to authenticate to the codec but he couldn't recall what they were.
Has anyone ever heard of this? I certainly haven't and neither has google as far as I can find.
Kenny
  • cmasoncmason Posts: 123
    I've never heard of a hex string for authentication. I've not seen it in any of the TC docs either.
    You'll just have to decide what kind of session you want to use (Telnet or SSH) and make sure it's enabled on the codec.
    Although, I have all my C90s connected via RS-232. I do use Telnet to run/test commands on my C90 from my computer though.
    Depending on how in depth your control is going to be, you may want to use serial instead of IP. Each time you connect to the codec (with IP), it is a new session and you'll have to re-register your feedback, etc...
    Good luck!
  • He might be talking about the typical negotiation a Telnet clients goes through with a host. An IP_CLIENT_OPEN doesn't go through any of the typical telnet client session arbitration. I have to manually do this to connect via IP to a Tesira unit. Let me know if this is what you need, I will post the code.
    Good point.
    I guess I've not had to send/receive strings from a telnet port yet.
    Can you post the code when you have a moment? I'm curious to look at it.
  • Tesira Telnet Client Session Arbitration Code
    Here's the code... basically, it's searching what the Tesira sends back for the specific challenge, then sending specific response strings back, to tell the Tesira basic information, supposedly about how the client handles certain Telnet codes and functions:
    while( find_string(rm[2].d[20].buffin, "$FF,$FD,$18, $FF,$FD,$20, $FF,$FD,$23, $FF,$FD,$27, $FF,$FD,$24", 1) ) {
        rm[2].d[20].buffin = "''" ///clear buffer
        rm[2].a[1].init = 1 ///Set "Init" response block
        call 'debug' ("'Sending Tesira Connection Challenge Response 1:',$FF,$FC,$18, $FF,$FC,$20, $FF,$FC,$23, $FF,$FC,$27, $FF,$FC,$24")
        send_string rm[2].d[20].ipcomm[1].devid, "$FF,$FC,$18, $FF,$FC,$20, $FF,$FC,$23, $FF,$FC,$27, $FF,$FC,$24"
    while(find_string( rm[2].d[20].buffin,"$FF,$FB,$03, $FF,$FD,$01, $FF,$FD,'"', $FF,$FD,$1F, $FF,$FB,$05, $FF,$FD,'!'",1 ) ) {
        call 'debug' ("'Sending Tesira Connection Challenge Response 2:', $FF,$FE,$03, $FF,$FC,$01, $FF,$FC,'"', $FF,$FC,$1F, $FF,$FE,$05, $FF,$FC,'!'")
        send_string rm[2].d[20].ipcomm[1].devid, "$FF,$FE,$03, $FF,$FC,$01, $FF,$FC,'"', $FF,$FC,$1F, $FF,$FE,$05, $FF,$FC,'!'"
    while(find_string( rm[2].d[20].buffin,"'Welcome to the Tesira Text Protocol Server...',$0D,$0A",1 ) ) {
        call 'debug' ("'Subscribe to Services...'")
    //    send_string rm[2].d[20].ipcomm[1].devid, "$0D,$0A"
        //subscribe to something ...
        rm[2].d[20].buffout = "rm[2].d[20].buffout,'LogicMeter1 subscribe state 1 "2 01 MicButton"', $0A"
        rm[2].d[20].buffout = "rm[2].d[20].buffout,'LogicMeter1 subscribe state 2 "2 02 MicButton"', $0A"
     .... (there's a bunch more subscription requests here) ....
        rm[2].d[20].buffout = "rm[2].d[20].buffout,'DEVICE get serialNumber', $0A"
    Then elsewhere in response parsing code, I have it looking for the device serial number, and clearing the INIT flag (which suppresses the code from thinking a subscribe response is actually a state change from the logicmeters)
    ACTIVE(  ( find_string( this_data, "'02292255'", 1 )> 0 || find_string( this_data, "'02292302'", 1 ) > 0 ) && rm[this_rm].a[1].init == 1 ): { //Room Init COMPLETE!
    	    call 'debug' ("'Room Init Complete:',itoa(this_rm),' DID:',itoa(this_did),' This SN:',this_data")
    	    rm[this_rm].a[1].init = 0
    Hope that helps!
    Thanks for posting the code.
    Do you know if the hex strings are universal for Telnet comm?
    I wouldn't think they would be device specific.
    I just looked at the Cisco API Reference Guide (TC 7.1) and I didn't find any reference to initiating a telnet session (yet there is info on connecting via telnet and registering feedback and such).
    I think I found some info that explains the negotiation happening with the hex strings.
    Yet another review of TELNET
    During the connection, enhanced characteristics other than those offered by the NVT may be negotiated either by the user or the application. This task is accomplished by embedded commands in the data stream. TELNET command codes are one or more octets in length and are preceded by an interpret as command (IAC) character, which is an octet with each bit set equal to one (FF hex). The following are the TELNET command codes:
       Commands      Code No.   Description
                     Dec Hex
       data                     All terminal input/output data.
       End subNeg    240 FO     End of option subnegotiation command.
       No Operation  241 F1     No operation command.
       Data Mark     242 F2     End of urgent data stream.
       Break         243 F3     Operator pressed the Break key or the
                                Attention key.
       Int process   244 F4     Interrupt current process.
       Abort output  245 F5     Cancel output from current process.
       You there?    246 F6     Request acknowledgment.
       Erase char    247 F7     Request that operator erase the previous
                                  character.
       Erase line    248 F8     Request that operator erase the previous
                                  line.
       Go ahead!     249 F9     End of input for half-duplex connections.
       SubNegotiate  250 FA     Begin option subnegotiation.
       Will Use      251 FB     Agreement to use the specified option.
       Won’t Use     252 FC     Reject the proposed option.
       Start use     253 FD     Request to start using specified option.
       Stop Use      254 FE     Demand to stop using specified option.
       IAC           255 FF     Interpret as command.
    Each negotiable option has an ID, which immediately follows the command for option negotiation, that is, IAC: command, option code. Following is a list of TELNET option codes:
       Option ID     Option Codes     Description
       Dec Hex
        0  0         Binary Xmit      Allows transmission of binary data.
        1  1         Echo Data        Causes server to echo back
                                      all keystrokes.
        2  2         Reconnect        Reconnects to another TELNET host.
        3  3         Suppress GA      Disables Go Ahead! command.
        4  4         Message Sz       Conveys approximate message size.
        5  5         Opt Status       Lists status of options.
        6  6         Timing Mark      Marks a data stream position for
                                      reference.
        7  7         R/C XmtEcho      Allows remote control of terminal
                                      printers.
        8  8         Line Width       Sets output line width.
        9  9         Page Length      Sets page length in lines.
       10  A        CR Use            Determines handling of carriage returns.
       11  B        Horiz Tabs        Sets horizontal tabs.
       12  C        Hor Tab Use       Determines handling of horizontal tabs.
       13  D        FF Use            Determines handling of form feeds.
       14  E        Vert Tabs         Sets vertical tabs.
       15  F        Ver Tab Use       Determines handling of vertical tabs.
       16 10       Lf Use             Determines handling of line feeds.
       17 11       Ext ASCII          Defines extended ASCII characters.
       18 12       Logout             Allows for forced log-off.
       19 13       Byte Macro         Defines byte macros.
       20 14       Data Term          Allows subcommands for Data Entry to
                                      be sent.
       21 15       SUPDUP             Allows use of SUPDUP display protocol.
       22 16       SUPDUP Outp        Allows sending of SUPDUP output.
       23 17       Send Locate        Allows terminal location to be sent.
       24 18       Term Type          Allows exchange of terminal type
                                      information.
       25 19       End Record         Allows use of the End of record code
                                      (0xEF).
       26 1A       TACACS ID          User ID exchange used to avoid more
                                      than 1 log-in.
       27 1B       Output Mark        Allows banner markings to be sent on
                                      output.
       28 1C       Term Loc#          A numeric ID used to identify terminals.
       29 1D       3270 Regime        Allows emulation of 3270 family
                                      terminals.
       30 1E       X.3 PAD            Allows use of X.3 protocol emulation.
       31 1F       Window Size        Conveys window size for emulation
                                      screen.
       32 20       Term Speed         Conveys baud rate information.
       33 21       Remote Flow        Provides flow control (XON, XOFF).
       34 22       Linemode           Provides linemode bulk character
                                      transactions.
       255 FF      Extended           options list  Extended options list.
    It makes sense that the two devices need to understand each other's capabilities.
  • NZRobNZRob Posts: 70
    I have used the C40 over IP and serial a bit lately - only thing changes is the telnet/serial selection (IP also needs IP set and user/password) - this is clearly shown in the examples
  • cmason wrote: »
    (code snipped out)
    Yes, that's exactly what is going on with those initialization strings. Thanks for the follow-up on that!
