HTTPS request with Duet ?
Hi
I need for a NetLinx module to do a GET requist on an HTTPS server. I know it's impossible to do in NetLinx code so I planned to use a Duet module to generate the HHTPS request (it's used to generate a token). Would someone have some codes to share ? I don't want to reinvent basic stuff and not much time to go deep in Duet and Java docs !
Vincèn
Vincèn
HTTPS is possible but will only be reliable with the new controllers.
I'd recommend using the httpclient module from Apache Commons. It can be a bit of a pain to compile against the Duet SDK, but if you download the 4.x RMS SDK you can grab the 4 commons- JARs from it, and include them in your project. Just make sure you're looking at the version 3.1 documentation from Apache Commons. My experience with the NI series controllers is that it's SLOOOOOOW. Roughly 10 seconds per request. From what I've heard of the NX controllers, I'd expect it to be much much faster.
