smtp_send can not attach the image file
Hi~
I am trying to capture the MET-ECOM camera image and through the smtp_send function sends the image to my gmail.
e.g.:
smtp_server_config_set(SMTP_ADDRESS,'smtp.gmail.com')
smtp_server_config_set(SMTP_PORT_NUMBER,'587')
smtp_server_config_set(SMTP_USERNAME,'xxx.xxx@gmail.com')
smtp_server_config_set(SMTP_PASSWORD,'password')
smtp_server_config_set(SMTP_REQUIRE_TLS, SMTP_TLS_TRUE)
smtp_server_config_set(SMTP_FROM,'xxx.xxx@gmail.com')
smtp_send(smtp,mail.toWho,mail.title,mail.body, 'ECOM.JPG')
I found smtp_send seems it will re-encode the image file and causing the file is damaged.
Is another way can send mail and incloud image file in netlinx?
Thank you.
P.S.: DVX-3155, firmware:v4.8.313
