Polycom SoundStructure Documentation
Can someone please help me find ANY documentation on the Polycom SoundStructure Duet Module?
There is nothing in the 3rd party Device Database that actually speaks to it, and the SNAPI documentation doesn't cover how to connect to it.
I tried building the module the same way the Group Series works (DATA_EV-->ONLINE-->Property IP, et al) but it won't connect. The Group Series Module works just fine.
I really need to grab control of this box, so I'd be very grateful if someone could point me in the right direction!
The sound structure model numbers are c8 or c16. You can find the documentation in the zip files under those models. If that information is not enough, tech support should be able to help.
Jeff, I didn't think to look inside of the c8. The documentation is there, but not in the c16 zip.
Thanks for the help guys!
Take phone off hook.
Dial number.
But for a Sip call it's the other way around.
Hola
Alguna vez controlé un equipo similar
te puedo pasar el codigo
