WRITE FILE INDEX ISSUE
HELP!
This may take a few passes through to figure out what I'm trying to accomplish.. but essentially I am trying to write to a structure that has a max legnth of 36. This works perfectly when booking a room, but for whatever reason the write file function extends the length of the cSUBJECT in the structure to 16 after each pass. I can't figure out why for the life of me.
PROGRAM_NAME='Calendar Demo Rev 1'
(*  FILE CREATED ON: 01/16/2015  AT: 08:00:17              *)
(*  FILE_LAST_MODIFIED_ON: 01/29/2015  AT: 11:14:13        *)
DEFINE_DEVICE
dvMaster	=	0:1:0
dvTP		=	10001:1:0
dvTP_Locked	=	10001:3:0
dvTP_Mtg	=	10001:4:0
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
MAX_USERS = 500
MAX_MEETINGS = 36
TL_FEEDBACK = 1
TL_FEEDBACK2 = 2
TL_FEEDBACK3 = 3
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
STRUCTURE _sUSERS //Presets Structure
    CHAR cID[15]
    CHAR cFIRST_NAME[25]
    CHAR cLAST_NAME[25]
    CHAR cEMAIL[50]
STRUCTURE _sMTG //Mtg Structure
    CHAR cHOST_NAME[25]
    CHAR cSTART_DATE[25]
    CHAR cSTART_HOUR[4]
    CHAR cSTART_MINUTE[4]
    CHAR cEND_HOUR[4]
    CHAR cEND_MINUTE[4]
    CHAR cSUBJECT[50]
(*               VARIABLE DEFINITIONS GO BELOW             *)
DEFINE_VARIABLE
PERSISTENT _sUSERS uUSERS[MAX_USERS]
PERSISTENT _sMTG uMTG[MAX_MEETINGS]
VOLATILE CHAR cDATA[25]
VOLATILE CHAR cBADGE[20]
VOLATILE INTEGER nVALID_ENTRY
VOLATILE INTEGER nDONE
VOLATILE CHAR cHOST_NAME[25]
VOLATILE CHAR cSTART_DATE[25]
VOLATILE CHAR cSTART_HOUR[4]
VOLATILE CHAR cSTART_MINUTE[4]
VOLATILE CHAR cEND_HOUR[4]
VOLATILE CHAR cEND_MINUTE[4]
VOLATILE CHAR cSUBJECT[50]
VOLATILE INTEGER nMINUTE
VOLATILE INTEGER nHOUR
VOLATILE INTEGER nMINUTE2
VOLATILE INTEGER nHOUR2
VOLATILE INTEGER nTIME
NON_VOLATILE sINTEGER nCURRENT_HOUR
NON_VOLATILE sINTEGER nCURRENT_MIN
NON_VOLATILE sINTEGER nCURRENT_MEETING
VOLATILE LONG nTIMER[] = {500}
VOLATILE LONG nTIMER2[] = {5000}
VOLATILE LONG nTIMER3[] = {10000}
VOLATILE INTEGER nCLOSED
NON_VOLATILE DEVCHAN dcMTGs[] =
{dvTP_Locked, 1},
{dvTP_Locked, 2},
{dvTP_Locked, 3},
{dvTP_Locked, 4},
{dvTP_Locked, 5},
{dvTP_Locked, 6},
{dvTP_Locked, 7},
{dvTP_Locked, 8},
{dvTP_Locked, 9},
{dvTP_Locked, 10},
{dvTP_Locked, 11},
{dvTP_Locked, 12},
{dvTP_Locked, 13},
{dvTP_Locked, 14},
{dvTP_Locked, 15},
{dvTP_Locked, 16},
{dvTP_Locked, 17},
{dvTP_Locked, 18},
{dvTP_Locked, 19},
{dvTP_Locked, 20},
{dvTP_Locked, 21},
{dvTP_Locked, 22},
{dvTP_Locked, 23},
{dvTP_Locked, 24},
{dvTP_Locked, 25},
{dvTP_Locked, 26},
{dvTP_Locked, 27},
{dvTP_Locked, 28},
{dvTP_Locked, 29},
{dvTP_Locked, 30},
{dvTP_Locked, 31},
{dvTP_Locked, 32},
{dvTP_Locked, 33},
{dvTP_Locked, 34},
{dvTP_Locked, 35},
{dvTP_Locked, 36}
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
(* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
(* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
DEFINE_FUNCTION INTEGER fnCONVERT_REQUEST (INTEGER nSTART_HOUR, INTEGER nSTART_MINUTE, INTEGER nEND_HOUR, INTEGER nEND_MINUTE)
    STACK_VAR INTEGER nDURATION
    STACK_VAR i
    STACK_VAR x
    IF(nSTART_HOUR == 1)
	nSTART_HOUR = 13
    ELSE IF(nSTART_HOUR == 2)
	nSTART_HOUR = 14
    ELSE IF(nSTART_HOUR == 3)
	nSTART_HOUR = 15
    ELSE IF(nSTART_HOUR == 4)
	nSTART_HOUR = 16
    IF(nEND_HOUR == 1)
	nEND_HOUR = 13
    ELSE IF(nEND_HOUR == 2)
	nEND_HOUR = 14
    ELSE IF(nEND_HOUR == 3)
	nEND_HOUR = 15
    ELSE IF(nEND_HOUR == 4)
	nEND_HOUR = 16
    ELSE IF(nEND_HOUR == 5)
	nEND_HOUR = 17
    i = ((nEND_HOUR - nSTART_HOUR)*60)
    x = nEND_MINUTE - nSTART_MINUTE
    nDURATION = i + x
    RETURN nDURATION
DEFINE_FUNCTION INTEGER fnPROCESS_TIME (INTEGER nHOUR, INTEGER nMINUTE)
    STACK_VAR INTEGER t
    IF(nHOUR > 12)
	nHOUR = nHOUR - 12
    IF(nHOUR == 8 && nMINUTE < 15)
	t = 1
    ELSE IF(nHOUR == 8 && nMINUTE >= 15 && nMINUTE < 30)
	t = 2
    ELSE IF(nHOUR == 8 && nMINUTE >= 30 && nMINUTE < 45)
	t = 3
    ELSE IF(nHOUR == 8 && nMINUTE >= 45)
	t = 4
    ELSE IF(nHOUR == 9 && nMINUTE < 15)
	t = 5
    ELSE IF(nHOUR == 9 && nMINUTE >= 15 && nMINUTE < 30)
	t = 6
    ELSE IF(nHOUR == 9 && nMINUTE >= 30 && nMINUTE < 45)
	t = 7
    ELSE IF(nHOUR == 9 && nMINUTE >= 45)
	t = 8
    ELSE IF(nHOUR == 10 && nMINUTE < 15)
	t = 9
    ELSE IF(nHOUR == 10 && nMINUTE >= 15 && nMINUTE < 30)
	t = 10
    ELSE IF(nHOUR == 10 && nMINUTE >= 30 && nMINUTE < 45)
	t = 11
    ELSE IF(nHOUR == 10 && nMINUTE >= 45)
	t = 12
    ELSE IF(nHOUR == 11 && nMINUTE < 15)
	t = 13
    ELSE IF(nHOUR == 11 && nMINUTE >= 15 && nMINUTE < 30)
	t = 14
    ELSE IF(nHOUR == 11 && nMINUTE >= 30 && nMINUTE < 45)
	t = 15
    ELSE IF(nHOUR == 11 && nMINUTE >= 45)
	t = 16
    ELSE IF(nHOUR == 12 && nMINUTE < 15)
	t = 17
    ELSE IF(nHOUR == 12 && nMINUTE >= 15 && nMINUTE < 30)
	t = 18
    ELSE IF(nHOUR == 12 && nMINUTE >= 30 && nMINUTE < 45)
	t = 19
    ELSE IF(nHOUR == 12 && nMINUTE >= 45)
	t = 20
    ELSE IF(nHOUR == 1 && nMINUTE < 15)
	t = 21
    ELSE IF(nHOUR == 1 && nMINUTE >= 15 && nMINUTE < 30)
	t = 22
    ELSE IF(nHOUR == 1 && nMINUTE >= 30 && nMINUTE < 45)
	t = 23
    ELSE IF(nHOUR == 1 && nMINUTE >= 45)
	t = 24
    ELSE IF(nHOUR == 2 && nMINUTE < 15)
	t = 25
    ELSE IF(nHOUR == 2 && nMINUTE >= 15 && nMINUTE < 30)
	t = 26
    ELSE IF(nHOUR == 2 && nMINUTE >= 30 && nMINUTE < 45)
	t = 27
    ELSE IF(nHOUR == 2 && nMINUTE >= 45)
	t = 28
    ELSE IF(nHOUR == 3 && nMINUTE < 15)
	t = 29
    ELSE IF(nHOUR == 3 && nMINUTE >= 15 && nMINUTE < 30)
	t = 30
    ELSE IF(nHOUR == 3 && nMINUTE >= 30 && nMINUTE < 45)
	t = 31
    ELSE IF(nHOUR == 3 && nMINUTE >= 45)
	t = 32
    ELSE IF(nHOUR == 4 && nMINUTE < 15)
	t = 33
    ELSE IF(nHOUR == 4 && nMINUTE >= 15 && nMINUTE < 30)
	t = 34
    ELSE IF(nHOUR == 4 && nMINUTE >= 30 && nMINUTE < 45)
	t = 35
    ELSE IF(nHOUR == 4 && nMINUTE >= 45)
	t = 36
    RETURN t
DEFINE_FUNCTION sINTEGER fnFILL_CALENDAR (INTEGER nCURRENT_HOUR, INTEGER nCURRENT_MIN)
    STACK_VAR INTEGER x
    STACK_VAR INTEGER nINDEX
    FOR(x=1; x<=MAX_LENGTH_ARRAY(uMTG); x++)
	IF(LENGTH_STRING(uMTG[x].cSUBJECT) > 0)
	    IF(uMTG[x].cSUBJECT == uMTG[x].cSUBJECT)
		ON[dvTP_Locked, x]
	ELSE
	    OFF[dvTP_Locked, x]
    IF(nCURRENT_HOUR > 12)
	nCURRENT_HOUR = nCURRENT_HOUR - 12
    nINDEX = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
    IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) > 0)
	SEND_COMMAND dvTP, "'^TXT-1,0,',uMTG[nINDEX].cSUBJECT"
	RETURN TRUE
    ELSE
	SEND_COMMAND dvTP, "'^TXT-1,0,Vacant'"
	RETURN FALSE
DEFINE_FUNCTION INTEGER fnPROCESS_REQUEST (INTEGER nINDEX, INTEGER nNUM_MTGs)
    STACK_VAR INTEGER i
    fnREAD_FILE_MTG('New_Mtg.csv')
    IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) < 1)
	FOR(i=1; i<=nNUM_MTGs; i++)
		RETURN TRUE
	    ELSE IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) > 1)
		RETURN FALSE
		BREAK;
	    nINDEX++
DEFINE_FUNCTION fnRead_BadgeID (CHAR cFILENAME[])
    LOCAL_VAR SLONG slFILE_VAL
    slFILE_VAL = FILE_OPEN(cFILENAME,FILE_READ_ONLY)
    IF(slFILE_VAL < 0)
	SELECT
	    ACTIVE(slFILE_VAL == -2): SEND_STRING 0, "'Invalid Path'"
	    ACTIVE(slFILE_VAL == -3): SEND_STRING 0, "'Invalid Value'"
	    ACTIVE(slFILE_VAL == -5): SEND_STRING 0, "'I/O Error'"
	    ACTIVE(slFILE_VAL == -14):SEND_STRING 0, "'Max Files Open'"
	    ACTIVE(slFILE_VAL == -15):SEND_STRING 0, "'Invalid File Format'"
    ELSE IF(slFILE_VAL > 0)
	LOCAL_VAR SLONG slVAL
	LOCAL_VAR INTEGER i
	LOCAL_VAR CHAR cBUFF[2048]
	FOR(i=1; i<=MAX_LENGTH_ARRAY(uUSERS); i++)
	    slVAL = FILE_READ_LINE(slFILE_VAL,cBUFF,MAX_LENGTH_ARRAY(cBUFF))
	    uUSERS[i].cID = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uUSERS[i].cID,LENGTH_STRING(uUSERS[i].cID)-1)
	    uUSERS[i].cFIRST_NAME = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uUSERS[i].cFIRST_NAME,LENGTH_STRING(uUSERS[i].cFIRST_NAME)-1)
	    uUSERS[i].cLAST_NAME = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uUSERS[i].cLAST_NAME,LENGTH_STRING(uUSERS[i].cLAST_NAME)-1)
	    uUSERS[i].cEMAIL = cBUFF
	FILE_CLOSE(slFILE_VAL)
DEFINE_FUNCTION fnREAD_FILE_MTG (CHAR cFILENAME[])
    IF(slFILE_VAL < 0)
	SELECT
	LOCAL_VAR INTEGER i
	STACK_VAR INTEGER x
	FOR(i=1; i<=MAX_LENGTH_ARRAY(uMTG); i++)
	    uMTG[i].cHOST_NAME = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cHOST_NAME,LENGTH_STRING(uMTG[i].cHOST_NAME)-1)
	    uMTG[i].cSTART_DATE = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cSTART_DATE,LENGTH_STRING(uMTG[i].cSTART_DATE)-1)
	    uMTG[i].cSTART_HOUR = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cSTART_HOUR,LENGTH_STRING(uMTG[i].cSTART_HOUR)-1)
	    uMTG[i].cSTART_MINUTE = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cSTART_MINUTE,LENGTH_STRING(uMTG[i].cSTART_MINUTE)-1)
	    uMTG[i].cEND_HOUR = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cEND_HOUR,LENGTH_STRING(uMTG[i].cEND_HOUR)-1)
	    uMTG[i].cEND_MINUTE = REMOVE_STRING(cBUFF,',',1)
	    SET_LENGTH_STRING(uMTG[i].cEND_MINUTE,LENGTH_STRING(uMTG[i].cEND_MINUTE)-1)
	    uMTG[i].cSUBJECT = cBUFF
DEFINE_FUNCTION fnWRITE_FILE_MTG(CHAR cFILENAME[])
    LOCAL_VAR SLONG slFILE_VAR
    LOCAL_VAR INTEGER i
    LOCAL_VAR SLONG slRESULT
    slFILE_VAR = FILE_OPEN(cFILENAME,FILE_RW_NEW)
    IF(slFILE_VAR > 0)
	    cBUFF = "uMTG[i].cHOST_NAME,',',uMTG[i].cSTART_DATE,',',uMTG[i].cSTART_HOUR,',',uMTG[i].cSTART_MINUTE,',',uMTG[i].cEND_HOUR,',',uMTG[i].cEND_MINUTE,',',uMTG[i].cSUBJECT"
	    slRESULT = FILE_WRITE_LINE(slFILE_VAR,cBUFF,LENGTH_STRING(cBUFF))
	FILE_CLOSE(slFILE_VAR)
	SEND_STRING 0,"'GOOD FILE CLOSED ',ITOA(FILE_CLOSE(slFILE_VAR))"
    ELSE
	SEND_STRING 0,"'BAD FILE OPEN ',ITOA(FILE_CLOSE(slFILE_VAR))"
(*                STARTUP CODE GOES BELOW                  *)
DEFINE_START
TIMELINE_CREATE(TL_FEEDBACK,  nTIMER,  1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) //Half Second
TIMELINE_CREATE(TL_FEEDBACK2, nTIMER2, 1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) // 5 Seconds
TIMELINE_CREATE(TL_FEEDBACK3, nTIMER3, 1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) //60 Seconds
(*                THE EVENTS GO BELOW                      *)
DEFINE_EVENT
DATA_EVENT[dvMaster] //Master Data Event
    ONLINE:
	SEND_COMMAND dvTP, "'ADBEEP'" //When online, BEEP!
    STRING:
	IF(FIND_STRING(DATA.TEXT, "'GOOD FILE CLOSED'", 1))
	    PULSE[nCLOSED]
DATA_EVENT[dvTP]
    STRING:
	STACK_VAR INTEGER x
	SEND_STRING 0, "'FROM TP: ', DATA.TEXT"
	SELECT
	    ACTIVE(FIND_STRING(DATA.TEXT, 'Button 16-', 1)):
		REMOVE_STRING(DATA.TEXT, 'Button 16-', 1)
		cBADGE = DATA.TEXT
		IF(LENGTH_STRING(cBADGE == 11))
		    fnRead_BadgeID('Badge_IDs.csv')
		    FOR(x=1; x<=MAX_LENGTH_ARRAY(uUSERS); x++)
			IF(cBADGE == uUSERS[x].cID)
			    SEND_COMMAND dvTP, "'@PPN-New Mtg'"
			    SEND_COMMAND dvTP, "'@PPK-Authorization'"
			    SEND_COMMAND dvTP, "'@PPK-Invalid Entry'"
			    SEND_COMMAND dvTP_Mtg, "'^TXT-1,0,',uUSERS[x].cFIRST_NAME,',',uUSERS[x].cLAST_NAME"
			    ON[nVALID_ENTRY]
			    cHOST_NAME = "uUSERS[x].cFIRST_NAME,' ',uUSERS[x].cLAST_NAME"
			    SEND_COMMAND dvTP_Mtg, "'^TXT-2,0,',DATE"
			    BREAK;
			ELSE
			    SEND_COMMAND dvTP, "'@PPN-Invalid Entry'"
			    OFF[nVALID_ENTRY]
			    WAIT 40
				SEND_COMMAND dvTP, "'PAGE-Locked'"
	    ACTIVE(FIND_STRING(DATA.TEXT, '@PPF-Authorization;Locked', 1)):
		SET_LENGTH_STRING(cHOST_NAME, 0)
		SET_LENGTH_STRING(cSTART_DATE, 0)
		SET_LENGTH_STRING(cSTART_HOUR, 0)
		SET_LENGTH_STRING(cSTART_MINUTE, 0)
		SET_LENGTH_STRING(cEND_HOUR, 0)
		SET_LENGTH_STRING(cEND_MINUTE, 0)
		SET_LENGTH_STRING(cSUBJECT, 0)
		SEND_COMMAND dvTP_Mtg, "'^TXT-3,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-4,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-6,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-11,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-12,0,'"
		SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,'"
	    ACTIVE(FIND_STRING(DATA.TEXT,'KEYB-',1)):
		REMOVE_STRING(DATA.TEXT,'KEYB-',1)
		cDATA = DATA.TEXT
	    ACTIVE(FIND_STRING(DATA.TEXT,'KEYP-',1)):
		REMOVE_STRING(DATA.TEXT,'KEYP-',1)
		IF(nTIME == 1)
		    nHOUR = ATOI(DATA.TEXT)
		ELSE IF(nTIME == 2)
		    nMINUTE = ATOI(DATA.TEXT)
		ELSE IF(nTIME == 3)
		    nHOUR2 = ATOI(DATA.TEXT)
		ELSE IF(nTIME == 4)
		    nMINUTE2 = ATOI(DATA.TEXT)
	PULSE[nDONE]
BUTTON_EVENT[dvTP_Mtg, 3]
    PUSH:
	TO[BUTTON.INPUT]
	nTIME = 1;
    RELEASE:
	WAIT_UNTIL(nDONE)
	    cSTART_HOUR = ITOA(nHOUR)
	    SEND_COMMAND dvTP_Mtg, "'^TXT-3,0,',cSTART_HOUR"
	    IF(nHOUR >= 8 && nHOUR < 12)
		SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,AM'"
	    ELSE
		SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,PM'"
BUTTON_EVENT[dvTP_Mtg, 4]
    PUSH:
	nTIME = 2;
    RELEASE:
	WAIT_UNTIL(nDONE)
	    cSTART_MINUTE = ITOA(nMINUTE)
	    IF(nMINUTE == 0)
		cSTART_MINUTE = "'00'"
	    SEND_COMMAND dvTP_Mtg, "'^TXT-4,0,',cSTART_MINUTE"
BUTTON_EVENT[dvTP_Mtg, 11]
    PUSH:
	nTIME = 3;
    RELEASE:
	WAIT_UNTIL(nDONE)
	    cEND_HOUR = ITOA(nHOUR2)
	    SEND_COMMAND dvTP_Mtg, "'^TXT-11,0,',cEND_HOUR"
	    IF(nHOUR2 >= 8 && nHOUR2 < 12)
		SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,AM'"
	    ELSE
		SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,PM'"
BUTTON_EVENT[dvTP_Mtg, 12]
    PUSH:
	nTIME = 4;
    RELEASE:
	WAIT_UNTIL(nDONE)
	    cEND_MINUTE = ITOA(nMINUTE2)
	    IF(nMINUTE2 == 0)
		cEND_MINUTE = "'00'"
	    SEND_COMMAND dvTP_Mtg, "'^TXT-12,0,',cEND_MINUTE"
BUTTON_EVENT[dvTP_Mtg, 6]
    PUSH:
    RELEASE:
	WAIT_UNTIL(nDONE)
	    cSUBJECT = cDATA
	    SEND_COMMAND dvTP_Mtg, "'^TXT-6,0,',cSUBJECT"
BUTTON_EVENT[dvTP_Mtg, 10] //reserve a new meeting
    PUSH:
	LOCAL_VAR INTEGER x
	LOCAL_VAR INTEGER INDEX
	LOCAL_VAR INTEGER nDURATION
	LOCAL_VAR INTEGER nNUM_MTGS
	LOCAL_VAR INTEGER ACCESS
	INDEX = fnPROCESS_TIME(nHOUR, nMINUTE)
	nDURATION = fnCONVERT_REQUEST(nHOUR, nMINUTE, nHOUR2, nMINUTE2)
	nNUM_MTGS = (nDURATION/15)
	ACCESS = fnPROCESS_REQUEST(INDEX, nNUM_MTGS)
	IF(LENGTH_STRING(cSUBJECT) > 0)
	    OFF[dvTP_Mtg, 16]
	    IF(ACCESS == 1)
		FOR(x=1; x<=nNUM_MTGS; x++)
		    uMTG[INDEX].cHOST_NAME    = cHOST_NAME
		    uMTG[INDEX].cSTART_DATE   = DATE
		    uMTG[INDEX].cSTART_HOUR   = cSTART_HOUR
		    uMTG[INDEX].cSTART_MINUTE = cSTART_MINUTE
		    uMTG[INDEX].cEND_HOUR     = cEND_HOUR
		    uMTG[INDEX].cEND_MINUTE   = cEND_MINUTE
		    uMTG[INDEX].cSUBJECT      = cSUBJECT
		    fnWRITE_FILE_MTG('New_Mtg.csv')
		    INDEX++
		    IF(x == nNUM_MTGs)
			BREAK;
		SEND_COMMAND dvTP, "'@PPX-New Mtg'"
	    ELSE IF(ACCESS == 0)
		SEND_COMMAND dvTP, "'@PPN-Error'"
	ELSE
	    ON[dvTP_Mtg, 16]
BUTTON_EVENT[dvTP, 4] //Cancel the current meeting
    PUSH:
	LOCAL_VAR INTEGER i
	LOCAL_VAR INTEGER nDURATION2
	LOCAL_VAR INTEGER nNUM_MTGs2
	LOCAL_VAR INTEGER nLINE
	nLINE = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
	nDURATION2 = fnCONVERT_REQUEST(ATOI(uMTG[nLINE].cSTART_HOUR), ATOI(uMTG[nLINE].cSTART_MINUTE), ATOI(uMTG[nLINE].cEND_HOUR), ATOI(uMTG[nLINE].cEND_MINUTE))
	nNUM_MTGs2 = (nDURATION2/15)
	FOR(i=1; i<=nNUM_MTGS2; i++)
	    SET_LENGTH_STRING(uMTG[nLINE].cHOST_NAME, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cSTART_DATE, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cSTART_HOUR, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cSTART_MINUTE, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cEND_HOUR, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cEND_MINUTE, 0)
	    SET_LENGTH_STRING(uMTG[nLINE].cSUBJECT, 0)
	    nLINE++
	    IF(i == nNUM_MTGs2)
		BREAK;
BUTTON_EVENT[dcMTGs]
    PUSH:
	STACK_VAR INTEGER BIC
	BIC = BUTTON.INPUT.CHANNEL
	ON[dvTP, 6]
	ON[dvTP, 7]
	IF(LENGTH_STRING(uMTG[BIC].cSUBJECT) > 0)
	    SEND_COMMAND dvTP, "'^TXT-2,0,',uMTG[BIC].cSUBJECT,' ',uMTG[BIC].cSTART_HOUR,':',uMTG[BIC].cSTART_MINUTE,' - ',uMTG[BIC].cEND_HOUR,':',uMTG[BIC].cEND_MINUTE"
	ELSE
	    SEND_COMMAND dvTP, "'^TXT-2,0,Meeting room available'"
	WAIT 50
	    OFF[dvTP, 6]
	    OFF[dvTP, 7]
BUTTON_EVENT[dvTP, 3]
    PUSH:
	STACK_VAR INTEGER y
	y = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
	IF(LENGTH_STRING(uMTG[y].cSUBJECT) > 0)
	    SEND_COMMAND dvTP, "'^TXT-3,0,',uMTG[y].cSUBJECT"
	ELSE
	    SEND_COMMAND dvTP, "'^TXT-3,0,There is no meeting to cancel...'"
TIMELINE_EVENT[TL_FEEDBACK]
    nCURRENT_HOUR = TIME_TO_HOUR(TIME)
    nCURRENT_MIN =  TIME_TO_MINUTE(TIME)
TIMELINE_EVENT[TL_FEEDBACK2]
    nCURRENT_MEETING = fnFILL_CALENDAR(nCURRENT_HOUR, nCURRENT_MIN)
TIMELINE_EVENT[TL_FEEDBACK3]
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
[dvTP, 1] = (nCURRENT_MEETING == 1)
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
  • cmasoncmason Posts: 123
    mjones2620 wrote: »
    HELP!
    DEFINE_DEVICE
    dvMaster	=	0:1:0
    dvTP		=	10001:1:0
    DEFINE_CONSTANT
    MAX_USERS = 500
    MAX_MEETINGS = 36
    TL_FEEDBACK = 1
    TL_FEEDBACK2 = 2
    TL_FEEDBACK3 = 3
    DEFINE_TYPE
        CHAR cID[15]
        CHAR cLAST_NAME[25]
        CHAR cEMAIL[50]
        CHAR cHOST_NAME[25]
        CHAR cSTART_HOUR[4]
        CHAR cEND_HOUR[4]
        CHAR cEND_MINUTE[4]
        CHAR cSUBJECT[50]
    DEFINE_VARIABLE
    {dvTP_Locked, 1},
    {dvTP_Locked, 2},
    {dvTP_Locked, 3},
    {dvTP_Locked, 4},
    {dvTP_Locked, 5},
    {dvTP_Locked, 6},
    {dvTP_Locked, 7},
    {dvTP_Locked, 8},
    {dvTP_Locked, 9},
    {dvTP_Locked, 10},
    {dvTP_Locked, 11},
    {dvTP_Locked, 12},
    {dvTP_Locked, 13},
    {dvTP_Locked, 14},
    {dvTP_Locked, 15},
    {dvTP_Locked, 16},
    {dvTP_Locked, 17},
    {dvTP_Locked, 18},
    {dvTP_Locked, 19},
    {dvTP_Locked, 20},
    {dvTP_Locked, 21},
    {dvTP_Locked, 22},
    {dvTP_Locked, 23},
    {dvTP_Locked, 24},
    {dvTP_Locked, 25},
    {dvTP_Locked, 26},
    {dvTP_Locked, 27},
    {dvTP_Locked, 28},
    {dvTP_Locked, 29},
    {dvTP_Locked, 30},
    {dvTP_Locked, 31},
    {dvTP_Locked, 32},
    {dvTP_Locked, 33},
    {dvTP_Locked, 34},
    {dvTP_Locked, 35},
    {dvTP_Locked, 36}
    DEFINE_LATCHING
        STACK_VAR i
        STACK_VAR x
    	nSTART_HOUR = 13
    	nSTART_HOUR = 14
    	nSTART_HOUR = 15
    	nSTART_HOUR = 16
        IF(nEND_HOUR == 1)
    	nEND_HOUR = 13
    	nEND_HOUR = 14
    	nEND_HOUR = 15
    	nEND_HOUR = 16
    	nEND_HOUR = 17
        nDURATION = i + x
        RETURN nDURATION
        STACK_VAR INTEGER t
        IF(nHOUR > 12)
    	nHOUR = nHOUR - 12
    	t = 1
    	t = 2
    	t = 3
    	t = 4
    	t = 5
    	t = 6
    	t = 7
    	t = 8
    	t = 9
    	t = 10
    	t = 11
    	t = 12
    	t = 13
    	t = 14
    	t = 15
    	t = 16
    	t = 17
    	t = 18
    	t = 19
    	t = 20
    	t = 21
    	t = 22
    	t = 23
    	t = 24
    	t = 25
    	t = 26
    	t = 27
    	t = 28
    	t = 29
    	t = 30
    	t = 31
    	t = 32
    	t = 33
    	t = 34
    	t = 35
    	t = 36
        RETURN t
        STACK_VAR INTEGER x
    		ON[dvTP_Locked, x]
    	ELSE
    	    OFF[dvTP_Locked, x]
    	RETURN TRUE
        ELSE
    	RETURN FALSE
        STACK_VAR INTEGER i
    		RETURN TRUE
    		RETURN FALSE
    		BREAK;
    	    nINDEX++
        IF(slFILE_VAL < 0)
    	SELECT
    	LOCAL_VAR INTEGER i
        IF(slFILE_VAL < 0)
    	SELECT
    	LOCAL_VAR INTEGER i
    	STACK_VAR INTEGER x
        LOCAL_VAR INTEGER i
        IF(slFILE_VAR > 0)
        ELSE
    DEFINE_START
    DEFINE_EVENT
        ONLINE:
        STRING:
    	    PULSE[nCLOSED]
    DATA_EVENT[dvTP]
        STRING:
    	STACK_VAR INTEGER x
    	SELECT
    		cBADGE = DATA.TEXT
    			    ON[nVALID_ENTRY]
    			    BREAK;
    			ELSE
    			    OFF[nVALID_ENTRY]
    			    WAIT 40
    		cDATA = DATA.TEXT
    		IF(nTIME == 1)
    		ELSE IF(nTIME == 2)
    		ELSE IF(nTIME == 3)
    		ELSE IF(nTIME == 4)
    	PULSE[nDONE]
        PUSH:
    	TO[BUTTON.INPUT]
    	nTIME = 1;
        RELEASE:
    	WAIT_UNTIL(nDONE)
    	    ELSE
        PUSH:
    	nTIME = 2;
        RELEASE:
    	WAIT_UNTIL(nDONE)
    	    IF(nMINUTE == 0)
        PUSH:
    	nTIME = 3;
        RELEASE:
    	WAIT_UNTIL(nDONE)
    	    ELSE
        PUSH:
    	nTIME = 4;
        RELEASE:
    	WAIT_UNTIL(nDONE)
    	    IF(nMINUTE2 == 0)
        PUSH:
        RELEASE:
    	WAIT_UNTIL(nDONE)
    	    cSUBJECT = cDATA
        PUSH:
    	LOCAL_VAR INTEGER x
    	    OFF[dvTP_Mtg, 16]
    	    IF(ACCESS == 1)
    		    INDEX++
    		    IF(x == nNUM_MTGs)
    			BREAK;
    	ELSE
    	    ON[dvTP_Mtg, 16]
        PUSH:
    	LOCAL_VAR INTEGER i
    	    nLINE++
    	    IF(i == nNUM_MTGs2)
    		BREAK;
        PUSH:
    	ON[dvTP, 6]
    	ON[dvTP, 7]
    	ELSE
    	WAIT 50
    	    OFF[dvTP, 6]
    	    OFF[dvTP, 7]
        PUSH:
    	STACK_VAR INTEGER y
    	ELSE
    DEFINE_PROGRAM
    When you say "extends cSubject to 16" do you mean it truncates the 50 characters to 16?
    Can you post the contents of the file?
  • cmason wrote: »
    it truncates to 16 yes, the file doesnt show any characters, although they may be blank spaces. Thoughts?
    The following line uses the "LENGTH_STRING" command:
    I'd change that to "LENGTH_ARRAY" and see if you get different results.
    I remember getting inconsistent results with the "LENGTH_STRING" command.
    Since it is an Axcess command, best to avoid it anyhow.
    Also, you may want to SEND_STRING 0 the "slRESULT" var to see how many characters are actually getting written to the line.
  • JasonSJasonS Posts: 229
    It would be a lot easier to use "VARIABLE_TO_STRING" and "STRING_TO_VARIABLE" to convert the whole structure array in one command. Just make sure to use "SET_LENGTH_ARRAY" on the structure array variable before converting it to a string.
    JasonS wrote: »
    Whoa... I've never seen that command before... or the VARIABLE_TO_XML command.
    Thanks for teaching me something new. What does it convert the structure to? A CSV line?
    I just re-read the Help on it. So it converts it to a binary string?
    Interesting...
    Be careful with the to XML string it does not work with nested structures. It will generate invalid XML.
    JasonS wrote: »
    Really? Doesn't that defeat the purpose for using XML?
    cmason wrote: »
    Not really, its more to do when you nest a structure, you know, put one sturcture within another.
    "Variable_To_String" has worked great for a single level of structure nesting for me, haven't tried with more. It also creates a smaller file than XML. The only downside is that it is not very human readable. Again make sure that you SET_LENGTH_ARRAY on any array variables (all dimensions) that you are converting. Also make sure that the variable you are reading the converted string back into is the the same size as the original. I use MAX_LENGTH_ARRAY to set the array lengths before converting.
