Are you asking how to set up / configure the device?
Or, how to program it for use with an existing system?
If the first - the documentation that came in the box (quick start) should have all the info you need to get it configured. If you don't ahve that just grab it from the AMX website. The manuals are all there. Just search by product model.
If the second situation: Post the code you're having trobule with anad we'll see what's going on.
E
[Deleted User]Harman Integrated Technologies Group (ITG)Posts: 591
D:P:S
Device:Port:System
The device will require that you configure it with a device number. The quick start guide should help you connect and configure this. Let's assume you give this a device 5002 number. With that decided, it is important to understand this product has 4 ports.
I always just scan the network to find the EXBs IP address, telnet into the device, set a static IP address, set the device number, reboot the device then find the device in the online tree, right-click and bind the device to the master. Once you have done it a time or two it's fast and easy.
While you are telneted into the device do "Set Connection", then you can skip the bind device to master step, it is already done.
E
Device:Port:System
Doest he device show up in the online tree?
Did you load in an IR file to the port? The device won't show a pulse unless there's an IR file loaded.
