Modero X camera stream not playing
We have an MXT-700 and MXT-701 right now, and I want to try making video calls between them.
I noticed that sending the command '?CAM' returns 'CAM-0,1' which according to the manual means that the camera is not supported and enabled. I don't think I was shipped with the wrong camera installed, but I may have to try other firmwares for this.
On the MXT-701, entering 'cam://local' on the camera settings streaming video URL results Can't play this video. Am I doing something wrong? Is there something that has to be done prior doing this? Is there a simple program somewhere to demonstrate this feature?
Generally you need to start the stream between the two devices. See PDF pages 119-120 here in the panel programming guide:
http://www.amx.com//assets/manuals/Modero.G4.Configuration.Programming.Guide.pdf
which means that my camera is not supported, but enabled.
One other thing, I noticed that videocom is not supported on the G5 panels yet. Will it be supported?
