Tell if its NX or NI in program?
Anyone know if you can tell if its a NX or NI in the program as I want to program to use the serial fault detect if its NX or use my old way for an NI in a serial module?
    The built in DEVICE_ID(<dev>) function sounds like what you are seeking. In PI, you can find the device ID for your product and in code, use the function to evaluate the device.
    http://www.amx.com/assets/AMX-PI2/amx-pi2.htm
    NX Master DEVICE ID: 0x018D or 0x1B7
  • ColzieColzie Posts: 470
    DEVICE_ID_STRING (0:1:0) works nicely too if you'd like an ASCII return. Look for NI or NX in the return string.
  • NZRobNZRob Posts: 70
    Thanks guys that worked well - String to NI pops up with 'NI Master' and guessing that a NX will pop up 'NX Master'. Will have to find one to test on and then serial test on.
    Short version within serial module:
    DEFINE_VARIABLE
        VOLATILE INTEGER bIs_NI 		= TRUE;
    DEFINE_EVENT
    DATA_EVENT [dvThisDevice]
        ONLINE:
            WAIT 100
    	    IF(FIND_STRING(DEVICE_ID_STRING(0:1:0),'NX',1)) bIs_NI = FALSE;
    Then just using bIs_NI is code for NI or NX control
