VPT-CP to VPN-CP conversion?
Does anyone know if its possible to upgrade a VPT-CP one-way panel to a VPN-CP two-way 2.4ghz panel, simply by inserting a two-way transceiver module and setting the internal jumper to 2-Way?
Thanks in advance
-Dave
Thanks in advance
-Dave
Vinc
First off you need the 2way card which connects to the front of the board which can only be obtained by AMX. This has a wire that goes to the reciever think it was made by a company called "Aerocomm". The newer Panele Rev 5.10a do not have the connectors on the the board. Rev 5.03e (I think...hard to remember) do. So you still need this part from AMX. Unless you have spare or broken VPT's lying around and are handy with this sort of thing.......my advice would be not to bother.
