MVP-7500 Wifi question
in AMX Hardware
Guys,
Is there a way when an MVP-7500 is connected to an Access Point and switches to another AP to get that information from the panel?
For example it would be ideal to be able to get the AP's name and store it inside the NI and when that name changes a popup window would appear to the user and inform him of the change.
Costas
Costas
You can request from AP if they are compatible for that list of devices connected and so you can know if MVP is connected on which one.
You can also setup each AP to be a DHCP server in a different range of IP for its wireless clients, and so you can check IP of MVP and know on which one it is connected. Inconvenient: ICSP connection will drop few seconds each time you change of AP, and so states of buttons will be lost on MVP.
Hope it helps
Vinc
-- John
