Studio 2.4: Should I?
I have been holding off on the move to Studio 2.4 because I am at the tail end of a large project and I don't want to introduce any new "features" to it. The question I have after monitoring the problems thread is: Are there any features in 2.4 that make it worthwhile to install immediately? I know that in order to compile java modules, I need 2.4. Is there anything else, should I wait for some hot fixes or the next version, or am I getting the wrong impression of 2.4?
I agree. Wait until we get a patch for Studio 2.4. If you are not have to compile Java Java files, You'll get - sorry - too much disadvantages at the moment....
If you want to use DUET modules from InCOncert, this is still possible with Studio 2.3
Not sure what I need to change, or if the .jar file was missing something, but I did have problems trying to use a DUET module from the InConcert section with v2.3.
1. The find window problem that seems to be our #1 complaint doesn't affect me because I always hit Ctrl-Home to go up to the top before searching.
A holdover from using AxcessX.
2. I don't seem to be affected by the speed issues that others seem to be having.
3. Even though there are some issues, there have been a number of minor bug fixes and enhancements. See the readme.
4. However, thanks to Dickster's Axcess code, we have found we have re-introduced an Axcess compiler problem.
If you have upgraded to v2.4 and need the v2.0.0.143 Axcess compiler, please email me guy.minervini@amx.com and and I will send it to you with instructions for installing it.
I see only 2 compelling reasons to upgrade at this time:
1. If you're using a Duet module created with the v1.5 Duet Runtime, you must upgrade to v2.4.
2. If you want to use the new Unicode functions, you must upgrade to v2.4.
I agree with Brian - if you're at the end of long project and everything's working well for you with v2.3, stay with v2.3 for now.
However, if someone has already installed v2.4 - I would not roll back, especially if you're not noticing any issues (other than the Axcess compiler issue which is easily fixed).
Thanks for everyone's replies.
Studio Build 126 has these improvements over build 123:
BUG FIX - Find dialog wasn't retaining the state of its various options.
BUG FIX - Axcess Compiler was not the correct version.
BUG FIX/FEATURE - Added a checkbox to NetLinx Compiler Option for enabling or disabling the _WC preprocessor when running the NetLinx compiler.
This is now, by default, disabled. If you wish to develop for UNICODE languages using the _WC macros, you will need to turn this option on. Otherwise, you can turn it off.
The NetLinx compiler is faster with this option disabled.
BUG FIX - Enhancements to the speed of the source code lexer.
I just installed Studio 2.4 build 126 on my notebook running XP Pro SP2. I am happy to report all went well with the install.
After a brief test, the problems I previously experienced have been addressed as per Guy's post.
I plan on putting the program into service for my programming needs.
I will be anxious to hear what the rest of you think.
Brian
Now, I install build 126 after build 123 was install and found compilation error.
Anyone has the same problem I have?
Otherwise, things look good.
