File Transfer Suggestion
Hello, I have a suggestion for the people that publish NetLinx Studio.
The most annoying thing about the Studio program - which is mostly excellent btw - happens to me often when I'm transferring files to a Master. Specifically, I'm sending a token and a TP4 file at the same time. I've left the TP4 open in the background because I was working on it, so I get an alert saying the thing can't be transferred because it's open. Fair enough.
But then after clicking OK I have to wait until the token gets sent and the Master reboots before I can attempt to send the TP4 file again! This happens to me a lot because I often lose track of whether a TP4 file is open, and when this happens it doubles the amount of time I have to wait to see the results of my latest work.
This problem could easily be solved by Studio giving me the opportunity to abort the transfer if it discovers that it is trying to send an open file. As it is now, the transfer isn't started yet, but the program only offers me an OK button, which I must click, and then look on in horror as the token shoots across. Again, if there were an 'Abort Transfer' button at this point it would save me a lot of time.
`mp
`mp
I have one particular .tp4 that renders differently depending on which program transfered it to the panel. When uploaded via Studio it doesn't look anything like what I have in TP4. When transfered with TP4 it looks and operates perfectly. I've never been to concerned with "why" as I use TP4 for all transfers now.
[BTW, all options (ie.. full transfer, etc..) are the same]
As DHawthorne said, it's more convenient any way.
Anyway, I thirdly agree with being able to transfer the TP file even though it's open.
I can understand if are potentially fatal complications to transferring a file that is being edited. I don't expect NetLinx Studio to be OK with that.
I just can't understand why Studio forces you to go through with the transfer once you discover that it won't be able to send the file.
I wonder if it would be faster to force-quit Studio next time that happens.
Right-mouse click within the "File Transfer Status" pane of the output bar. The context-menu have the following options for canceling file transfers:
Cancel Current Transfer
Cancel Selected Transfer Items
Cancel Remaining Transfer Items
Cancel All Transfer Items.
Still, it would be nice if there were a way to prevent that transfer from starting...
