Sony CDPCE375
I have a Sony CDPCE375 5 Disc changer that is behaving strangely. I cannot get direct disc selection to work in program, but when I pulse the IR out from IR Edit, it works everytime, even at 1/10th sec. pulse time. I have tried capturing the IR codes from the remote, and have the same behavior. Any help resolving this would be greatly appreciated.
Have you tried using a different emitter or a different port to rule out hardware mulfunctions? The only other thing I can think of is did you set the pulse time in your programming before pulsing? The last thing I can think to ask is are you able to get any codes to work, like play stop or ffw?
Hope some of this helps, if not post the answers to the above questions and I'll try to help more, or possibly someone having experience with that unit will have some better advice.
To answer your questions - yes I have tried different emitters and ports, yes I have set the pulse times, and the time between pulses, and yes all other codes work. In fact the device is misinterpreting two of the codes, Disc 3 is being interpreted as disc skip, and disc 1is changing a play mode, but I cannot duplicate the exact action with the remote.
Hope things work out,
