Create a resources file - two questions
All:
I've searched for an answers for these on the forum, but couldn't find them. If they're here can you point me to the topics?
Q1 - In other programming, many of the common items (strings, image files, layouts) are contained in a resources files. To assist my faculty, I'm working on a number of help popups or tool tips to be dynamically generated on the touch panel. However, I'd rather not have to open and re-compile source code simply to correct a spelling error, clean-up wording or similar correction. I'd simply like a resource file with my help strings that I can edit in notepad and have it called at runtime.
I thought the answer would be, as in php and others, to create an include file. I figured I could call it with #INCLUDE, but I can't seem to create a file that simply contains....
Do I need to add #IF_NOT_DEFINED for all my touch panels as part of the include?
Q2 - What would be the best way to add a CR/LF to a multi-line help file?
1. Here's step one. (CR/LF)
2. How about step two (CR/LF)
3. If you're here, you've gone too far.
TIA for all your help.
DEFINE_CONSTANT ttMakeCall = 'Here's the tooltip that tells faculty how to place a call.' ttConference = 'Here's the tooltip with hints about conferencing' . . .
2) The send_command to update text on a touch panel will read the pipe character " | " as a CR/LF equivalent so a string like this: "one|word|per|line" will do what it says.
FYI - If you are capturing user data from the touch panel keyboard and saving that out to a file, you might want to filter for CR/LF, since that will come back as part of the keyboard input, and translate it into " | " to put in the save file.
