TV's with either IP or RS232 Control
Had the email last night that Sharp are pulling out of the LCD TV Market which is a shame as they had a great product IMO
The big question now is what TV's out there are reliably controllable via either IP or RS232 - prefer not to use IR
cheers
cheers
To be honest, I've been doing mostly IR nowadays anyway. It's really the only constant and consistent method left to us. rs232 is getting hard to find and IP is just too easy for the manufacturers to constantly change - especially since the current sales-think is "It's gotta be cloud based" I don't know how many times I've seen stuff quit working after the integrator did a firmware upgrade on their displays. I have kind of learned over time how to 'fairly' reliably track display power with the need to occasionally double-clutch the IR power commands for TVs that may ignore the first one.
I will also say, that properly installed and managed IR has been very reliable as long as there are discrete commands for power/source/aspect AND the ir emitter heads are installed well with silicone adheasive (not the stupid stickers) AND AND AND the monitors are nowhere near children or pets. (The last is vital)
I honestly wouldn't call the Sharp IP controls realiable though, if for any reason you lose the connection you have (had?) to hard reset the entire TV.
I think this is a good point... the most oft heard argument against IR control is the whole "Reliability Issue" and the "I have no way of knowing what's going on with the device" argument. But, as I count in my head a good chunk of the other methods are pretty much the same thing. IP control tends to be flaky at times and as I've already said, more than once I've been burned by a stupid firmware upgrade. Many IP controlled devices don't offer feedback and are pretty much "Send it and hope..."
IR is not a good solution. Perhaps it's better to call it the less-crappy solution since it tends to not change over time.
You either have complex IP control or IR-over-IP when it comes to consumer level devices. With the complex IP protocols you basically get the 5+ seconds to connect you get when you try to use your smartphone to control your TV. (The horrible apps we've all seen)
IRCO0157 - UP
IRCO0120 - DOWN
IRCO01D7 - LEFT
IRCO01D8 - RIGHT
IRCO0152 - OK
IRCO01E4 - BACK
IRCO01F5 - END
IRCO11C6 - MENU
IRCO0114 - VOL +
IRCO0115 - VOL -
IDIN0081 - Home Network
IDIN0082 - USB Media
IRCO11F4 - HDMI1 - Default !
IRCO11F5 - HDMI2
IRCO11F8 - HDMI3
IRCO1195 - HDMI4
IRCO1197 - PC VGA
ITVD0000 - TV INPUT
IRCO11ED - EXT1
IRCO11EE - EXT2
IRCO11EF - EXT3
IRCO0148 - RED
IRCO0149 - GREEN
IRCO014A - YELLOW
IRCO014B - BLUE
IRCO11A3 - EPG
IRCO1133 - 3D
IRCO01F8 - AVMODE
IRCO11C8 - ZOOM
IRCO11F3 - ATV
IRCO11A0 - DTV
IRCO118D - SAT
IRCO11A4 - RADIO
IRCO0111 - CH UP
IRCO0112 - CH DOWN
IRCO0101 - 1
IRCO0102 - 2
IRCO0103 - 3
IRCO0104 - 4
IRCO0105 - 5
IRCO0106 - 6
IRCO0107 - 7
IRCO0108 - 8
IRCO0109 - 9
IRCO0113 - AV SOURCE
IRCO0127 - PREVIEW
IRCO11A8 - P.INFO
IRCO0118 - AUDIO MODE
IRCO1137 - ECO
IRCO011B - I+
