Error with Structure Array
All:
I've added a structure, then tried to create an array based on that structure. On compile I get: Symbol [ROOMARRAY] already defined in scope.
Here's my code
DEFINE_TYPE
STRUCTURE sRoomInfo
    CHAR LongName [40]
    CHAR ShortName [40]
    CHAR IPAddress [40]
DEFINE_VARIABLE
sRoomInfo RoomArray[4]
RoomArray[1].LongName  = 'Living Room'
RoomArray[1].ShortName  =  'LR'
RoomArray[1].IPAddress  = '192.168.1.100'
RoomArray[2].LongName  = Kitchen'
RoomArray[2].ShortName  = 'K'
RoomArray[2].IPAddress  = '192.168.1.101'
RoomArray[3].LongName  = 'Bedroom 1'
RoomArray[3].ShortName  = 'BR 1'
RoomArray[3].IPAddress  = '192.168.1.200'
RoomArray[4].LongName  = 'Bedroom 1'
RoomArray[4].ShortName  = 'BR2'
RoomArray[4].IPAddress  = '192.168.1.201'
This seems to be the syntax in the help file. However, the file also mentions the array and elements should be in braces. I've tried several variations of braces, but then I get an "Initializer is not a constant" error.
TIA for any help.
Norm
    normschaef wrote: »
    All:
    Here's my code
    DEFINE_TYPE
    STRUCTURE sRoomInfo
    CHAR LongName [40]
    CHAR ShortName [40]
    CHAR IPAddress [40]
    DEFINE_VARIABLE
    TIA for any help.
    Norm
    Hi Norm!
    this section of code is the problem:
    essnetially you are trying to re-define the variable.
    The easiest way to keep what you have and not have to retype like crazy is to just put the code in the DEFINE_START section.
    DEFINE_START
  • normschaefnormschaef Posts: 17
    Eric
    In this case, I couldn't trust the documentation ....
    Thanks for setting me on the straight and narrow.
    Norm
    yeah, it's a good idea to read it first. But, it doesn't always turn out to be true. If you get into a snag iwht it, you know my number. e
