PHAL policy?
What the heck is a PHAL policy? I get nothing from google. I recently updated a media server to it's latest SW rev and I no longer get dynamic cover art pics. This is what I get with msg on all on the TP (MXT-1000).
VTG 06/18 20:40:35.39 [1132262496] (vtg.graphic/debug) TcpRequest::openServer openServer FAILURE - retrying
VTG 06/18 20:40:35.39 [1132262496] (vtg.graphic/debug) TcpRequest::establishTCPConnection host=[192.168.1.47] port=[9000], interface=[eth0]
VTG 06/18 20:40:35.39 [1132262496] (vtg.graphic/debug) TcpRequest::establishTCPConnection Not binding to preferred interface due to PHAL policy
VTG 06/18 20:40:35.39 [1132262496] (vtg.network/debug) SetupNetwork::setDeviceIP: Convert it 192.168.1.47 final[192.168.1.47]
From the preceding log, it appears the connection to the server 192.168.1.47:9000 failed, and that would seem like a server issue. If that is the connection for the media server, maybe the new SW rev of the media server changed the connection properties. Can't really tell more than that.
Lately it seems for every step forward I take two more backwards.
The panel update commands: So if it is a server side problem why does it discriminate against the newer panels and not the older?
Were there portions of the firmware that got phased in or is this something that might stop working again.
I did call TS about it and then informed them that the new iPad also worked and sent them the MSG ON ALL print outs following the event trigger but never heard back from them even to say they're looking into it as a legit issue and they'll investigate it, not just amusing me and hoping I go away. Last time I called regarding a possible AMX home take over job they couldn't supply me with the missing stock files from the 2008 period of AMX home and when I asked questions about the prog.zip file all I got was "we're not aware of that file in AMX Home" and I didn't want to explain to TS about the prog.zip file. Now I realize why I never call TS. I'm glad others have had better results with TS but in the 1/2 a dozen or so times I've called in the last 10+ years I haven't been impressed.
Ahh goos fraba..... venting over!
