Couple code coding questions
Hi, I need to reboot a device every 24 hours, would the below code be reliable. Would the code only happen once at 4am? are there any chances that the command would get missed? Also how do I set the clock on the processor (not using code)?
DEFINE_PROGRAM
IF (TIME = '04:00:00'){
OFF [RELAYS,Device]
WAIT 100 ON [RELAYS,Device]
Next, if SEND_COMMAND TP1, "'@SOU-soundfile.mp3'" plays a MP3, how do I stop the audio from playing? is there a command for this? What happens whilst the first audio is playing and then I start a 2nd audio. Would they both be playing at the same time or will the 2nd one interrupt the first audio?
    Nope. This IF depends on making a time read at the exact millisecond you specify. You need a larger window, but not large enough to trigger a second time when it reboots.
    You can set the clock from the Netlinx Web manager, or from telnet or terminal, or from any touch panel.
    Sounds like you need to schedule some training with AMX, it is pretty hard to find your way without it.
  • vmailvmail Posts: 11
    With AMX UK they don't train you with everything about AMX, They just have a set list.
  • RaphayoRaphayo Posts: 111
    Better to use a timeline for your time event.
    To be sure you didn't retrig it, when you time match, you pause your timeline for 1 seconds and restart it.
    Or you set your timeline to time to 1 second.
    Priop i was using define program for feedback and time event. After locking some processor i define a function feedback who was recall only in define program. Now with the nx serie i'm using timeline. Very easy to managed.
    Here's an include file I use for time functions on the main side of my systems that you might find useful. In the update time function it calls several functions which in turn I use to call functions in my main or other includes that require it. You'd be interested in the fnRun_HourEvents() which calls fnMain_EveryHour(nCopyHour); which is a function you'll need to create in your main code to trigger your reboot with something like:
    DEFINE_FUNCTION fnMain_EveryHour(INTEGER iHour)
         if(iHour == 1)//everday at 1 am
          reboot(0);
    The functions are only called once per hour so you don't have to worry about repeated reboots. There's also a lot of other useful crap in this include that you'll find handy as you progress in your coding.
    Let me know if the attachment works cuz it doesn't for me. Stupid new forum sucks!
    I don't think the attachment in the last post works cuz of this new stupid forum so here's the .axi I mentioned.
    PROGRAM_NAME='VAV_Date_&_Time'
    (*  FILE_LAST_MODIFIED_ON: 07/31/2015  AT: 09:12:26        *)
    DEFINE_CONSTANT //DST                           <<<*************************  CHANGE SETTING PER JOB *********************************>>>
    //Typically clocks are adjusted forward one hour near the start of spring and are adjusted backward in autumn.[1]
    //Starting in 2007, Daylight Saving Time (DTS) has been extended by one month. Therefore, the start date of DTS in the United States has been
    //changed to the 2nd Sunday in March and the end date of DTS has been changed to the 1st Sunday in November
    //If Daylight Savings Time is currently being observed (between spring and fall), set this item to "1". If Daylight Savings Time
    //is not currently being observed (between fall and spring) or is not observed in your geographic location, set this item to "0".
    //This item is used to correctly calculate the times for sunrise and sunset.
    INTEGER DST_OBSERVED        = 1;          //1 for yes and 0 for no
    INTEGER DST_OFFSET        = 1;          //number of hours time is offset
    INTEGER DST_BEGIN_MONTH        = 3;          //March (months 1-12 January to December)
    INTEGER DST_END_MONTH        = 11;         //November (months 1-12 January to December)
    INTEGER DST_BEGIN_DAY        = 1;          //Sunday (day of week 1-7 Sunday to Saturday)
    INTEGER DST_END_DAY        = 1;          //Sunday (day of week 1-7 Sunday to Saturday)
    INTEGER DST_BEGINDAY_OCCURANCE    = 2;          //Number of occurances of that day in that month (2nd Sunday)
    INTEGER DST_ENDDAY_OCCURANCE    = 1;          //Number of occurances of that day in that month (1st Sunday)
    CHAR DST_BEGIN_TIME[]        = '02:00:00';    //Time change occurs
    CHAR DST_END_TIME[]        = '02:00:00';    //Time change occurs
    DEFINE_CONSTANT //ASTRO_CLOCK LAT/LONG          <<<*************************  CHANGE SETTING PER JOB *********************************>>>
    INTEGER CLKMGR_DST        = 1;         //1 for ON and 0 for OFF
    INTEGER CLKMGR_DST_OFFSET_HR    = 1;         //1 for 1 hour
    INTEGER CLKMGR_DST_OFFSET_MIN    = 0;         //0 for 0 minutes
    INTEGER CLKMGR_DST_OFFSET_SEC    = 0;         //0 for 0 seconds
    INTEGER CLKMGR_RESYNC_PERIOD    = 240;         //in minutes 480 = 8 hours, choices: 5 min, 15 min, 2 hour, 4 hours & (8 hours?)
                                //the web interface doesn't show an 8 hour option but the keyword example only shows
                                //an hour hour example. So I choose the highest the web gui lists 4 hours/240 minutes.
    DOUBLE CLKMGR_LAT        = -73.42;    //Longitude - Longitude in Degrees.Fraction of Degrees. West longitudes must be negative.
    DOUBLE CLKMGR_LONG        = 41.98;     //Latitude - Latitude in Degrees.Fraction of Degrees. South latitudes must be negative
    DOUBLE CLKMGR_OFFSET_GMT_EST    = -5.0;      //HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as
    DOUBLE CLKMGR_OFFSET_GMT_EDT    = -4.0;      //HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as
    CHAR CLKMGR_TIME_ZONE[]        = 'UTC-05:00';    //Input string must have the correct format: UTC[+|-]HH:MM
    CHAR CLKMGR_ACTIVESERVER[]     = '132.163.4.101';
    DEFINE_CONSTANT //TIME CONSTANTS Days of Week & Month of Year
    SUNDAY            = 1;
    MONDAY            = 2;
    TUESDAY           = 3;
    WEDNESDAY         = 4;
    THURSDAY          = 5;
    FRIDAY            = 6;
    SATURDAY          = 7;
    JANUARY        = 1;
    FEBRUARY    = 2;
    MARCH        = 3;
    APRIL        = 4;
    MAY        = 5;
    JUNE        = 6;
    JULY         = 7;
    AUGUST        = 8;
    SEPTEMBER    = 9;
    OCTOBER        = 10;
    NOVEMBER    = 11;
    DECEMBER    = 12;
    FIRST           = 1;
    SECOND          = 2;
    THIRD           = 3;
    FOURTH          = 4;
    FIFTH           = 5;
    EXPIRES_IN_SECONDS          = 10;
    INTEGER NUM_SECONDS_MINUTE    = 60;
    INTEGER NUM_SECONDS_30MIN    = 1800;
    INTEGER NUM_SECONDS_HOUR    = 3600;
    LONG NUM_SECONDS_DAY            = 86400;
    INTEGER NUM_MINUTES_HOUR    = 60;
    INTEGER NUM_MINUTES_DAY        = 1440;
    CHAR DAY_OF_WEEK_ABREV[7][3]   = {'SUN','MON','TUE','WED','THU','FRI','SAT'}
    CHAR DAY_OF_WEEK_FULL[7][9]    = {'Sunday','Monday','Tuesday','Wednesday','Thursday','Friday','Saturday'}
    CHAR MONTH_OF_YR_ABREV[12][3]   = {'Jan','Feb','Mar','Apr','May','Jun','Jul','Aug','Sep','Oct','Nov','Dec'};
    CHAR MONTH_OF_YR_FULL[12][9]    = {'January','February','March','April','May','June','July','August','September','October','November','December'};
    CHAR DAYS_MONTHs[12]            = {31   ,28   ,31   ,30   ,31   ,30   ,31   ,31   ,30   ,31   ,30   ,31};
    CHAR DAYS_LEAPMONTHs[12]        = {31   ,29   ,31   ,30   ,31   ,30   ,31   ,31   ,30   ,31   ,30   ,31};
    DEFINE_CONSTANT //UI FEEDBACK EVENTS
    FB_TIME_TIME           = 1;
    FB_TIME_SUNRISE        = 2;
    FB_TIME_SUNSET        = 3;
    FB_TIME_DST        = 4;
    FB_TIME_HOLIDAY        = 5;
    DEFINE_TYPE     //TIME STUFF
    STRUCTURE _sMyTime
         INTEGER     nYear;
         INTEGER     nMonth;
         INTEGER     n24Hour;
         INTEGER     n12Hour;
         INTEGER     nMinute;
         INTEGER     nSecond;
         INTEGER     nDayOfMonth;
         INTEGER     nDayOfWeek;
         INTEGER      nDayOccurance[7];
         LONG    nTime_Seconds;
         LONG    nTime_Minutes;
         CHAR    c24Time[8];
         CHAR    c12Time[8];
         INTEGER     nWeekOfMonth;
         INTEGER     nPlusDays;
         INTEGER     nDaytime;
         INTEGER    nTimePM_flag;
         CHAR       cAMPM[2];
         LONG         nSunriseTime;
         LONG         nSunSetTime;
         CHAR     cSunrise[10];
         CHAR     cSunset[10];
         INTEGER     nSunset24Hour;
         INTEGER     nSunset12Hour;
         INTEGER     nSunsetMinute;
         INTEGER     nSunsetSecond;
         INTEGER     nSunriseHour;
         INTEGER     nSunriseMinute;
         INTEGER     nSunriseSecond;
         CHAR         cHoliday[24];
         CHAR         cDay[3];
         CHAR         cDate[8];
         CHAR     cWebCurDateTime[29];
         CHAR     cWebExpDateTime[29];
    DEFINE_TYPE     //DST
    STRUCTURE _sMyDST
         INTEGER nDST_Active;
         INTEGER nOffset;
         INTEGER nObserved;
         INTEGER nBEG_Month;
         INTEGER nEND_Month;
         INTEGER nBEG_Day;
         INTEGER nEND_Day;
         INTEGER nBEG_DAY_Occurance;
         INTEGER nEND_DAY_Occurance;
    DEFINE_TYPE     //_sGet_ClkMgr
    STRUCTURE _sGet_ClkMgr
         INTEGER nReSyncPeriod;
         INTEGER nIs_DST_On;
         CHAR cTimeZone[9];
         CHAR cDST_StartRule[128];
         CHAR cDST_EndRule[128];
         CLKMGR_TIMESERVER_STRUCT sActiveTimeServer;
         CLKMGR_TIMEOFFSET_STRUCT sOffset;
         CLKMGR_TIMESERVER_STRUCT sTimeServers[4];
    DEFINE_TYPE     //CLKMGR_TIMEOFFSET_STRUCT FROM NETLINX.AXI FOR REFERNCE ONLY
    STRUCTURE CLKMGR_TIMEOFFSET_STRUCT
         INTEGER     HOURS;
         INTEGER     MINUTES;
         INTEGER     SECONDS;
    DEFINE_VARIABLE //STRUCTURES
    PERSISTENT _sMyTime sMyTime;
    VOLATILE   _sMyDST sMyDST;
    VOLATILE   _sGet_ClkMgr sGet_ClkMgr;//just holds the get queries
    VOLATILE INTEGER nTimeWait_Force = 1;
    VOLATILE INTEGER nTime_DeBug = 1;
    DEFINE_VARIABLE //TIMELINE
    VOLATILE LONG nTL_TIME_RT[] = {250};
    DEFINE_FUNCTION LONG fnConv_24HrTimeToSeconds(CHAR iTime[])
         RETURN ((((ATOI(REMOVE_STRING(iTime,"':'",1)) * 60) + ATOI(REMOVE_STRING(iTime,"':'",1))) * 60) + ATOI(iTime));
    DEFINE_FUNCTION CHAR[8] fnConv_SecondsTo24HrTime(LONG iTimeInSeconds)
         RETURN   "right_string("'0',ITOA(iTimeInSeconds / 3600)",2),':',
                right_string("'0',ITOA((iTimeInSeconds % 3600) / 60)",2),':',
                 right_string("'0',ITOA((iTimeInSeconds % 3600) % 60)",2)";
    DEFINE_FUNCTION CHAR[30] fnDo_24hrTimeAddition(CHAR iLDate[],CHAR i24HourTime[],LONG iSecondsAdded)
         STACK_VAR INTEGER nYear;       //change to all stack_var's
         STACK_VAR INTEGER nMonth;
         STACK_VAR INTEGER nLeap;
         STACK_VAR CHAR c24HrTime[8];
         STACK_VAR CHAR cNewDate[10];
         STACK_VAR LONG nDay;
         STACK_VAR LONG nDaysOver;
         STACK_VAR LONG nSecondsRemain;
         STACK_VAR LONG nTotalTimeSeconds;
         nTotalTimeSeconds = fnConv_24HrTimeToSeconds(i24HourTime) + iSecondsAdded;
         nMonth = atoi("REMOVE_STRING(iLDATE,"'/'",1)");
         nDay   = atoi("REMOVE_STRING(iLDATE,"'/'",1)");
         nYear  = atoi("iLDATE");
         if(nTotalTimeSeconds > NUM_SECONDS_DAY)
          STACK_VAR INTEGER i;
          nDaysOver = nTotalTimeSeconds / NUM_SECONDS_DAY;
          nSecondsRemain = nTotalTimeSeconds % NUM_SECONDS_DAY;
          if(!(nYear % 4))//http://en.wikipedia.org/wiki/Leap_year
               nLeap = 1;
               if(!(nYear % 100))//double check these rules??????
                if(nYear % 400)
                 nLeap = 0;
          if(nLeap)
               if((nDaysOver + nDay) > DAYS_LEAPMONTHs[nMonth])
                nDaysOver = nDaysOver - (DAYS_LEAPMONTHs[nMonth] - nDay);
                nMonth++;
                for(nMonth = nMonth; nDaysOver > DAYS_LEAPMONTHs[nMonth]; nMonth++)
                 nDaysOver = (nDaysOver - DAYS_LEAPMONTHs[nMonth]);
                 if(nMonth == 12)
                      nMonth = 1;
                      nYear ++;
                nDay = nDaysOver;
               else
                nDay = nDaysOver + nDay;
          else
               if((nDaysOver + nDay) > DAYS_MONTHs[nMonth])
                nDaysOver = nDaysOver - (DAYS_MONTHs[nMonth] - nDay);
                nMonth++;
               for(nMonth = nMonth; nDaysOver > DAYS_MONTHs[nMonth]; nMonth++)
                 nDaysOver = (nDaysOver - DAYS_MONTHs[nMonth]);
                 if(nMonth == 12)
                      nMonth = 1;
                      nYear ++;
                nDay = nDaysOver;
               else
          c24HrTime = fnConv_SecondsTo24HrTime(nSecondsRemain);
         else
          c24HrTime = fnConv_SecondsTo24HrTime(nTotalTimeSeconds);
         cNewDate = "right_string("'0',ITOA(nMonth)",2),'/',right_string("'0',ITOA(nDay)",2),'/',right_string("'0',ITOA(nYear)",2)";
         RETURN "DAY_OF_WEEK_ABREV[TYPE_CAST(DAY_OF_WEEK(cNewDate))],', ',itoa(nDay),' ',MONTH_OF_YR_ABREV[nMonth],' ',itoa(nYear),' ',c24HrTime";
    DEFINE_FUNCTION fnFB_Time(INTEGER iUI_Indx,INTEGER iEvent) //<< SET VT ADDRESS CHANNELS  CHANGE SETTING PER JOB **********************>>>
         SWITCH(iEvent)
          CASE FB_TIME_TIME:
               //panels can handle time on their own
          CASE FB_TIME_SUNRISE:
               fnFB_TimeSend_VT(iUI_Indx,1,"'Sunrise at ',itoa(sMyTime.nSunriseHour),':',itoa(sMyTime.nSunriseMinute),' AM'");
          CASE FB_TIME_SUNSET:
               fnFB_TimeSend_VT(iUI_Indx,2,"'Sunset at ',itoa(sMyTime.nSunset12Hour),':',itoa(sMyTime.nSunsetMinute),' PM'");
          CASE FB_TIME_DST:
               if(sMyDST.nDST_Active)
                //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: IN EFFECT'");
               else
                //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: NOT IN EFFECT'");
          CASE FB_TIME_HOLIDAY:
               fnFB_TimeSend_VT(iUI_Indx,4,"sMyTime.cHoliday");
    DEFINE_FUNCTION fnFB_TimeSend_VT(INTEGER iUI_Indx,INTEGER iCHAN,CHAR iStrMSG[500])
         STACK_VAR INTEGER n;
         STACK_VAR INTEGER nTPCount;
         STACK_VAR INTEGER nLoopStart;
         if(iUI_Indx)
          nTPCount = iUI_Indx;
          nLoopStart = iUI_Indx;
         else
          nTPCount = NUM_UIs_IN_SYSTEM;
          nLoopStart = 1;
         //fnTime_DeBug("'SEND_VT: ',iStrMSG,' :DEBUG <',itoa(__LINE__),'>'");
         for(n = nLoopStart; n <= nTPCount; n++)
          SWITCH(nUI_TypeArry[n])
               CASE UI_TYPE_G4:
               CASE UI_TYPE_R4:
               CASE UI_TYPE_MIO_DMS:
               (* no need for uni strings!!!
                STACK_VAR WIDECHAR cSTRING1[500];
                STACK_VAR CHAR cSTRING2[500];
                cSTRING1 = WC_DECODE(iStrMSG,WC_FORMAT_UTF8,1);
                cSTRING2 = WC_ENCODE(cSTRING1,WC_FORMAT_TP,1);
                //fnTime_DeBug("'^UNI- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'");
                SEND_COMMAND dvUI_Arry[n], "'^UNI-',itoa(iCHAN),',0,',cSTRING2";
               CASE UI_TYPE_G3:
               CASE UI_TYPE_iPHONE://uni not supported yet
               CASE UI_TYPE_iPAD:
               CASE UI_TYPE_iTOUCH:
                //fnTime_DeBug("'^TXT- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'");
                SEND_COMMAND dvUI_Arry[n], "'TEXT',itoa(iCHAN),'-',iStrMSG";
               CASE UI_TYPE_METKP:
               CASE UI_TYPE_UNKNOWN:
               CASE UI_TYPE_VIRTUAL:
                //DO NOTHING
         RETURN;
    DEFINE_FUNCTION fnTime_DeBug(CHAR iStr[])
         if(nTime_DeBug)
          STACK_VAR CHAR cCopyStr[1024];
          STACK_VAR INTEGER nLineCount;
          cCopyStr = iStr;
          nLineCount ++;
          WHILE(length_string(cCopyStr) > 100)
               SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',get_buffer_string(cCopyStr,100)";
               nLineCount ++;
          if(length_string(cCopyStr))
               SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',cCopyStr";
         RETURN;
    DEFINE_FUNCTION fnGet_DST_State()
         {//don't care about the hour of day it actually occurs!
         fnTime_DeBug("'fnCheckDST_Rule(): Checking DST State :DEBUG <',ITOA(__LINE__),'>'");
         SELECT
          ACTIVE(sMyTime.nMonth < DST_BEGIN_MONTH || sMyTime.nMonth > DST_END_MONTH):
               {//quick elimination
               sMyDST.nDST_Active = 0;
          ACTIVE(sMyTime.nMonth > DST_BEGIN_MONTH && sMyTime.nMonth < DST_END_MONTH):
               sMyDST.nDST_Active = 1;
          ACTIVE(sMyTime.nMonth == DST_BEGIN_MONTH):
               if(sMyTime.nDayOccurance[sMyDST.nBEG_Day] >= sMyDST.nBEG_DAY_Occurance)
               else
          ACTIVE(sMyTime.nMonth == DST_END_MONTH):
               if(sMyTime.nDayOccurance[sMyDST.nEND_Day] >= sMyDST.nEND_DAY_Occurance)
               else
          ACTIVE(TRUE):
               fnTime_DeBug("'fnCheckDST_Rule(): DST Check Error! :DEBUG <',ITOA(__LINE__),'>'");
               RETURN;
          fnTime_DeBug("'fnCheckDST_Rule(): DST is Active! :DEBUG <',ITOA(__LINE__),'>'");
         else
          fnTime_DeBug("'fnCheckDST_Rule(): DST is In-Active! :DEBUG <',ITOA(__LINE__),'>'");
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_DST);
         RETURN;
    DEFINE_FUNCTION fnGet_AstroClock()
         LOCAL_VAR SINTEGER nTimeMngr_Result;
         fnTime_DeBug("'fnAstro_Clock(): Running ArtoClock! :DEBUG <',ITOA(__LINE__),'>'");
         sGet_ClkMgr.cTimeZone = CLKMGR_GET_TIMEZONE();
         sGet_ClkMgr.nReSyncPeriod = CLKMGR_GET_RESYNC_PERIOD();
         sGet_ClkMgr.nIs_DST_On = CLKMGR_IS_DAYLIGHTSAVINGS_ON();// this only return whether it's observed or not not if it's active, very stupid!
         sGet_ClkMgr.cDST_EndRule = CLKMGR_GET_END_DAYLIGHTSAVINGS_RULE();
         sGet_ClkMgr.cDST_StartRule = CLKMGR_GET_START_DAYLIGHTSAVINGS_RULE();
         CLKMGR_GET_TIMESERVERS(sGet_ClkMgr.sTimeServers);
         CLKMGR_GET_DAYLIGHTSAVINGS_OFFSET(sGet_ClkMgr.sOffset);
         CLKMGR_GET_ACTIVE_TIMESERVER(sGet_ClkMgr.sActiveTimeServer);
         if(sMyDST.nObserved)
          fnGet_DST_State();
         //SINTEGER ASTRO_CLOCK(DOUBLE Longitude,DOUBLE Latitude,DOUBLE HoursFromGMT,CHAR[] Date,CHAR[] Sunrise,CHAR[] Sunset)
         if(sMyDST.nDST_Active)//
          nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EDT,LDATE,sMyTime.cSunrise,sMyTime.cSunset);
         else
          nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EST,LDATE,sMyTime.cSunrise,sMyTime.cSunset);
         fnTime_DeBug("'fnAstro_Clock(): Sunset Time = ',sMyTime.cSunset,' :DEBUG <',ITOA(__LINE__),'>'");
         sMyTime.nSunset24Hour = atoi(left_string(sMyTime.cSunset,2));
         sMyTime.nSunsetMinute = atoi(mid_string(sMyTime.cSunset,4,2));
         sMyTime.nSunsetSecond = atoi(right_string(sMyTime.cSunset,2));
         sMyTime.nSunsetTime   =  ((((sMyTime.nSunset24Hour * 60) + sMyTime.nSunsetMinute) * 60) + sMyTime.nSunsetSecond);
         if(sMyTime.nSunset24Hour >= 12)
          sMyTime.nSunset12Hour = sMyTime.nSunset24Hour - 12;
         else//yeah, I know!
          sMyTime.nSunset12Hour = sMyTime.nSunset24Hour;
         fnTime_DeBug("'fnAstro_Clock(): Sunrise Time = ',sMyTime.cSunrise,' :DEBUG <',ITOA(__LINE__),'>'");
         sMyTime.nSunriseHour   = atoi(left_string(sMyTime.cSunrise,2));
         sMyTime.nSunriseMinute = atoi(mid_string(sMyTime.cSunrise,4,2));
         sMyTime.nSunriseSecond = atoi(right_string(sMyTime.cSunrise,2));
         sMyTime.nSunriseTime   = ((((sMyTime.nSunriseHour * 60) + sMyTime.nSunriseMinute) * 60) + sMyTime.nSunriseSecond);
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNRISE);
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNSET);
    DEFINE_FUNCTION fnGet_DayOccurrences()
         if(sMyTime.nDayOfWeek && sMyTime.nDayOfMonth)
          STACK_VAR INTEGER nD_O_W;
          sMyTime.nWeekOfMonth = sMyTime.nDayOfMonth / 7;
          sMyTime.nPlusDays  = sMyTime.nDayOfMonth % 7;
          for(i = 1; i <= 7; i ++)//first erase stored values
               sMyTime.nDayOccurance[i] = 0;
          nD_O_W = sMyTime.nDayOfWeek;
          sMyTime.nDayOccurance[nD_O_W] ++;
          for(i = sMyTime.nDayOfMonth; i > 1; i --)
               if(nD_O_W > 1)
                nD_O_W -- ;
               else
                nD_O_W = 7;
          fnTime_DeBug("'fnFindDayOccurences(): The First Day of the Month= ',DAY_OF_WEEK_ABREV[nD_O_W],' (',itoa(nD_O_W),') :DEBUG <',ITOA(__LINE__),'>'");
          fnTime_DeBug("'fnFindDayOccurences(): Weeks= ',itoa(sMyTime.nWeekOfMonth),', Days= ',itoa(sMyTime.nPlusDays),
                 ', Day= ',itoa((sMyTime.nWeekOfMonth * 7) + sMyTime.nPlusDays),' of ',MONTH_OF_YR_ABREV[sMyTime.nMonth],' :DEBUG <',ITOA(__LINE__),'>'");
         else
          fnTime_DeBug("'fnFindDayOccurences(): Error! No Value in sMyTime.nDayOfWeek or sMyTime.nDayOfMonth :DEBUG <',ITOA(__LINE__),'>'");
    DEFINE_FUNCTION fnGet_Holiday()
         sMyTime.cHoliday = '';
         SWITCH(sMyTime.nMonth)
          CASE JANUARY:
               SELECT
                ACTIVE(sMyTime.nDayOfMonth == 1):
                 sMyTime.cHoliday = 'New Years Day';
                ACTIVE(sMyTime.nDayOccurance[MONDAY] == THIRD && sMyTime.nDayOfWeek == MONDAY):
                 sMyTime.cHoliday = "'M.L.King',39,'s Birthday'";
          CASE FEBRUARY:
               SELECT
                ACTIVE(sMyTime.nDayOfMonth == 2):
                 sMyTime.cHoliday = 'Ground Hog Day';
                ACTIVE(sMyTime.nDayOfMonth == 14):
                 sMyTime.cHoliday = "'Valentine',39,'s Day'";
                ACTIVE(sMyTime.nDayOfMonth == 22):
                 sMyTime.cHoliday = "'G. Washington',39,'s Birthday'";
                 sMyTime.cHoliday = "'President',39,'s Day'";
          CASE MARCH:
               SELECT
                ACTIVE(sMyTime.nDayOfMonth == 9):
                 sMyTime.cHoliday = "'Employee Appreciation Day'";
                ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14):
                 sMyTime.cHoliday = "'Aniversary in ',itoa(14-sMyTime.nDayOfMonth),' days'";
                 STACK_VAR INTEGER nYears;
                 nYears = sMyTime.nYear - 1984;
                 SWITCH(nYears)
                      CASE 1:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'st Aniversary!'";}
                      CASE 2:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'nd Aniversary!'";}
                      CASE 3:{sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'rd Aniversary!'";}
                      DEFAULT:
                       sMyTime.cHoliday = "'Jack & Jill''s ',itoa(nYears),'th Aniversary!'";
                ACTIVE(sMyTime.nDayOfMonth == 17):
                 sMyTime.cHoliday = "'ST Patrick',39,'s Day'";
               //EASTER?
          CASE APRIL:
               SELECT
                 sMyTime.cHoliday = "'April Fool',39,'s Day'";
                 sMyTime.cHoliday = "'Patriot',39,'s Day'";
          CASE MAY:
               SELECT
                ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth < 5):
                 sMyTime.cHoliday = "'Jill''s birthday in ',itoa(5-sMyTime.nDayOfMonth),' days'";
                 sMyTime.cHoliday = "'Jill''s birthday!'";
                ACTIVE(sMyTime.nDayOccurance[SUNDAY] == SECOND && sMyTime.nDayOfWeek == SUNDAY):
                 sMyTime.cHoliday = "'Mother''s Day'";
                ACTIVE(sMyTime.nDayOccurance[SATURDAY] == THIRD && sMyTime.nDayOfWeek == SATURDAY):
                 sMyTime.cHoliday = "'Armed Forces Day'";
                ACTIVE(sMyTime.nDayOccurance[MONDAY] == FOURTH && sMyTime.nDayOfMonth > 24 && sMyTime.nDayOfWeek == MONDAY):
                 sMyTime.cHoliday = 'Memorial Day';
                ACTIVE(sMyTime.nDayOccurance[MONDAY] == FIFTH && sMyTime.nDayOfWeek == MONDAY):
          CASE JUNE:
               SELECT
                 sMyTime.cHoliday = "'Flag Day'";
                ACTIVE(sMyTime.nDayOfMonth == 21):
                 sMyTime.cHoliday = "'Summer Solstice'";
                ACTIVE(sMyTime.nDayOccurance[SUNDAY] == THIRD && sMyTime.nDayOfWeek == SUNDAY):
                 sMyTime.cHoliday = "'Father',39,'s Day'";
          CASE JULY:
               if(sMyTime.nDayOfMonth == 4)
                sMyTime.cHoliday = 'Independence Day';
          CASE AUGUST:
               if(sMyTime.nDayOccurance[SUNDAY] == FIRST && sMyTime.nDayOfWeek == SUNDAY)
                sMyTime.cHoliday = "'Friendship Day'";
          CASE SEPTEMBER:
               if(sMyTime.nDayOccurance[MONDAY] == FIRST && sMyTime.nDayOfWeek == MONDAY)
                sMyTime.cHoliday = 'Labor Day';
          CASE OCTOBER:
               if(sMyTime.nDayOfMonth == 31)
                sMyTime.cHoliday = 'Halloween';
          CASE NOVEMBER:
               SELECT
                 sMyTime.cHoliday = "'All Saint',39,'s Day'";
                ACTIVE(sMyTime.nDayOfMonth == 11):
                 sMyTime.cHoliday = "'Veteran',39,'s Day'";
                ACTIVE(sMyTime.nDayOccurance[THURSDAY] == FOURTH && sMyTime.nDayOfWeek == THURSDAY):
                 sMyTime.cHoliday = 'Thanksgiving Day';
          CASE DECEMBER:
               SELECT
                ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth <= 23):
                 sMyTime.cHoliday = "ITOA(25 - sMyTime.nDayOfMonth),' days to Christmas'";
                 sMyTime.cHoliday = 'Winter Solstice';
                ACTIVE(sMyTime.nDayOfMonth == 24):
                 sMyTime.cHoliday = 'Christmas Eve';
                ACTIVE(sMyTime.nDayOfMonth == 25):
                 sMyTime.cHoliday = 'Christmas Day';
                ACTIVE(sMyTime.nDayOfMonth == 31):
                 sMyTime.cHoliday = "'New Year',39,'s Eve'";
         if(length_string(sMyTime.cHoliday))
          sMyTime.cHoliday = "'"',sMyTime.cHoliday,'"'";
          fnTime_DeBug("'fnFindHolidays(): Today is ',sMyTime.cHoliday,' :DEBUG <',ITOA(__LINE__),'>'");
         else
          fnTime_DeBug("'fnFindHolidays(): Today is not a "supported" holiday! :DEBUG <',ITOA(__LINE__),'>'");
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_HOLIDAY);
         RETURN;
    DEFINE_FUNCTION fnGet_WebDATE_TIME()
         sMyTime.cWebCurDateTime = "fnDo_24hrTimeAddition(LDate,TIME,0),' EST'";
         sMyTime.cWebExpDateTime = "fnDo_24hrTimeAddition(LDate,TIME,EXPIRES_IN_SECONDS),' EST'";
         RETURN;
    DEFINE_FUNCTION fnRun_SunRise_n_Set(INTEGER iDaytime)
         //SWITCH(iDaytime)
    //      CASE 0:{} //night
    //      CASE 1:{} //day
         fnMain_SunRise_n_Set(iDaytime);
    DEFINE_FUNCTION fnRun_D_O_W_Events(INTEGER iDayOfWeek)   //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyDOW;
         nCopyDOW = iDayOfWeek;
         //SELECT ACTIVE or SWITCH CASE to do something
    DEFINE_FUNCTION fnRun_D_O_M_Events(INTEGER iDayOfMonth)  //<<**************  CHANGE SETTING PER JOB **********************************>>>
         {//uncomment call in fnUpdate_Time()
         STACK_VAR INTEGER nCopyDOM;
         nCopyDOM  = iDayOfMonth;
    DEFINE_FUNCTION fnRun_DailyEvents()                      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         //fnDailyEmailTest();
         fnGet_Holiday();
         fnGet_AstroClock();
         fnMain_EveryDay();
    DEFINE_FUNCTION fnRun_HourEvents(INTEGER iHour)          //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyHour;
         nCopyHour  = iHour;
    DEFINE_FUNCTION fnRun_MinuteEvents(INTEGER iMinute)      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyMinute;
         nCopyMinute  = iMinute;
         fnMain_EveryMinute(nCopyMinute);
    DEFINE_FUNCTION fnRun_SecondEvents(INTEGER iSecond)      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopySecond;
         nCopySecond = iSecond;
         SELECT//add as needed
          ACTIVE(sMyTime.n24Hour == 23):
               if(sMyTime.nMinute == 59)
                if(nCopySecond == 59)
                 {//used for log entry
                 SEND_STRING 0,"'TIME-[ ',TIME,' ].  End day and begin a new!'";
         fnGet_WebDATE_TIME();
         fnMain_EverySecond(nCopySecond);
    DEFINE_FUNCTION fnRun_StartUpCode()
         LOCAL_VAR CLKMGR_TIMEOFFSET_STRUCT sMyCLKMGR_TIMEOFFSET;
         fnTime_DeBug("'fnRunStartUpCode(): Run Start Up! :DEBUG <',ITOA(__LINE__),'>'");
         sMyDST.nObserved = DST_OBSERVED;
          sMyDST.nOffset    = DST_OFFSET;
          sMyDST.nBEG_Month    = DST_BEGIN_MONTH;
          sMyDST.nEND_Month     = DST_END_MONTH;
          sMyDST.nBEG_Day       = DST_BEGIN_DAY;
          sMyDST.nEND_Day     = DST_END_DAY;
          sMyDST.nBEG_DAY_Occurance = DST_BEGINDAY_OCCURANCE;
          sMyDST.nEND_DAY_Occurance = DST_ENDDAY_OCCURANCE;
         WAIT 300//3000
          fnTime_DeBug("'fnRunStartUpCode(): Run Start Up Wait items! :DEBUG <',ITOA(__LINE__),'>'");
          CLKMGR_SET_CLK_SOURCE(CLKMGR_MODE_NETWORK); // or CLKMGR_MODE_STANDALONE
          CLKMGR_SET_ACTIVE_TIMESERVER (CLKMGR_ACTIVESERVER);
          CLKMGR_SET_TIMEZONE(CLKMGR_TIME_ZONE);
          CLKMGR_SET_DAYLIGHTSAVINGS_MODE(TRUE);//moved to DST function
          CLKMGR_SET_START_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_BEGINDAY_OCCURANCE),',',itoa(DST_BEGIN_DAY),',',itoa(DST_BEGIN_MONTH),',',DST_BEGIN_TIME" );
          CLKMGR_SET_END_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_ENDDAY_OCCURANCE),',',itoa(DST_END_DAY),',',itoa(DST_END_MONTH),',',DST_END_TIME" );
          CLKMGR_SET_RESYNC_PERIOD(CLKMGR_RESYNC_PERIOD);
          sMyCLKMGR_TIMEOFFSET.HOURS   = CLKMGR_DST_OFFSET_HR;
          sMyCLKMGR_TIMEOFFSET.MINUTES = CLKMGR_DST_OFFSET_MIN;
          sMyCLKMGR_TIMEOFFSET.SECONDS = CLKMGR_DST_OFFSET_SEC;
          CLKMGR_SET_DAYLIGHTSAVINGS_OFFSET(sMyCLKMGR_TIMEOFFSET);
          nTimeWait_Force = 2;
          fnUpdate_Time();
         if(!TIMELINE_ACTIVE(TL_TIME))
          TIMELINE_CREATE(TL_TIME,nTL_TIME_RT,1,timeline_absolute,timeline_repeat);
    DEFINE_FUNCTION fnUpdate_Time()
         if(sMyTime.nSecond != TYPE_CAST(TIME_TO_SECOND(TIME)) || nTimeWait_Force)
          sMyTime.nSecond = TYPE_CAST(TIME_TO_SECOND(TIME));
          sMyTime.c24Time = TIME;
          if(sMyTime.nMinute != TYPE_CAST(TIME_TO_MINUTE(TIME)) || nTimeWait_Force)
               sMyTime.nMinute = TYPE_CAST(TIME_TO_MINUTE(TIME));
               //only 1 minute resolution for sunrise/set, could check every second but why, not that critical.....
               if(sMyTime.nTime_Seconds >= sMyTime.nSunriseTime && sMyTime.nTime_Seconds < sMyTime.nSunsetTime)
                if(!sMyTime.nDaytime)
                 sMyTime.nDaytime = 1;
                 fnRun_SunRise_n_Set(sMyTime.nDaytime);
               else
                if(sMyTime.nDaytime)
                 sMyTime.nDaytime = 0;
               if(sMyTime.n24Hour != TYPE_CAST(TIME_TO_HOUR(TIME)) || nTimeWait_Force)
                sMyTime.n24Hour = TYPE_CAST(TIME_TO_HOUR(TIME));
                if(sMyTime.n24Hour >= 12)
                 sMyTime.cAMPM = 'PM';
                 sMyTime.nTimePM_flag = 1;
                 if(sMyTime.n24Hour > 12)
                      sMyTime.n12Hour = sMyTime.n24Hour - 12;
                 else
                      sMyTime.n12Hour = sMyTime.n24Hour;
                else
                 sMyTime.cAMPM = 'AM';
                 sMyTime.nTimePM_flag = 0;
                sMyTime.c12Time = "itoa(sMyTime.n12Hour),':',RIGHT_STRING("'0',itoa(sMyTime.nMinute)",2),':',RIGHT_STRING("'0',itoa(sMyTime.nSecond)",2)";
                if(sMyTime.nDayOfMonth != TYPE_CAST(DATE_TO_DAY(LDATE)) || nTimeWait_Force)
                 sMyTime.nDayOfMonth = TYPE_CAST(DATE_TO_DAY(LDATE));
                 sMyTime.nDayOfWeek = TYPE_CAST(DAY_OF_WEEK(LDATE));
                 if(sMyTime.nMonth != TYPE_CAST(DATE_TO_MONTH(LDATE)))//no force here.  would erase stored values.
                      sMyTime.nMonth = TYPE_CAST(DATE_TO_MONTH(LDATE));
                      if(sMyTime.nYear != TYPE_CAST(DATE_TO_YEAR(LDATE)))
                       sMyTime.nYear = TYPE_CAST(DATE_TO_YEAR(LDATE));
                 if(sMyTime.cDay != Day || nTimeWait_Force)
                      sMyTime.cDay = Day;
                      if (sMyTime.cDate != Date)
                       sMyTime.cDate = Date;
                 fnGet_DayOccurrences();
                 fnRun_D_O_W_Events(sMyTime.nDayOfWeek);
                 fnRun_D_O_M_Events(sMyTime.nDayOfMonth);
                 fnRun_DailyEvents();
                fnRun_HourEvents(sMyTime.n24Hour);
               else
               sMyTime.nTime_Minutes = ((sMyTime.n24Hour * 60) + sMyTime.nMinute);
               fnRun_MinuteEvents(sMyTime.nMinute);
          else
          sMyTime.nTime_Seconds = ((((sMyTime.n24Hour * 60) + sMyTime.nMinute) * 60) + sMyTime.nSecond);
          fnRun_SecondEvents(sMyTime.nSecond);
          fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_TIME); //IF ANYTHING NEEDS TIME UPDATES
         nTimeWait_Force  = 0;
    DEFINE_START    //RUN START UP CODE
    fnRun_StartUpCode();
    DEFINE_EVENT    //TIMELINE_EVENT [TL_TIME]
    TIMELINE_EVENT [TL_TIME]//EVERY 250ms
         fnUpdate_Time();
         fnMain_250ms_Clock();//put any other timing events in the main in this function
    DEFINE_PROGRAM  //CALL fnUpdate_Time() if you don't have a timeline elsewhere to call it every second
    WAIT 10
         fnUpdate_Time();
