SMTP Function in Firmware v4.xx on which NIXXX possible?
hi
how can me tell on which NI900/700 is it possible to install the v4.xx Firmware with SMTP-Function?
Which ser-number are supported?
thanks
john
    the easiest way is check the RAM/Disk size. It must be at least 64mb. If not, then you don't have the model.
  • Thank you!
    Or look at the serial numbers.
    Early 700's with 32 meg start "210503x....." and newer ones with 64 meg start with "210570x...."
    All 900's have the larger memory.
