Just Add Power module using JAD Config
imsoco
I am updating a switch at an install that has been working for years using JAPs. The new configurator works great and makes it much easier to set up a system. The AMX module, though is giving me trouble when sending 232 commands through a receiver. The ASCII string will send characters fine, but translates the spaces to hex $20. The TV will not accept that. Docklight scripting will send the same command properly through the receiver and does work the TV.
Has anyone else had this problem?
The reason for the post is that I was told by JAP tech support that they have lots of people using this module without a problem. I need to know if it is something I missed or is the module screwed up. It is not an issue any more since I rolled my own.
Jap is a pretty solid device, but it basically is not controlled by AMX. The switch does all the work, AMX controls the VLAN's. It is more important to evaluate the switch in depth rather than the JAP system.
The SVSI system is much better from what I hear. My son has a couple hundred running on a large hotel system and swears by it.
