NX Series - "Don't Use Def_Program" and Modules
So, we're not supposed to use define_program anymore. I haven't used it in years anyway. But, what about modules? I happen to know I'm using several AMX written modules where I also happen to know they do use define_program in the code. What does that mean? and does it also cause issues? I imagine it would.
actually cause any problems.
You will, however, encounter issues if you are changing variables e.g., flash = !flash with the NX series. The SX80 module, for instance, has some feedback that looks to be more or less harmless.
I did change it to a TL just for good measure.
As I said, I haven't put anything in Def_Prog in years. But, Modules are black boxes. We have no idea what's going on in them. Perhaps AMX could come up with a little logo to indicate "This Module guaranteed to be Define_Program Free" People like logos, right?
Differences in DEFINE_PROGRAM Program Execution Page 12,13,14
An idle application normally runs below 5% of the CPU. If your idle application shows more usage than this, then it is probable that
your application is experiencing excessive execution of the DEFINE_PROGRAM section.
You can use the following diagnostic to diagnose executions of the DEFINE_PROGRAM section:
>superuser 10
>enable interp stats
>show interp stats
-- Mainline Executions due to:
Variable Change : 0
Variable Change : 50927
Variable Change : 62295
Variable Change : 72386
Notice the ?Variable Change? count is increasing rapidly.
These diagnostics will not tell you where in your application the offending code resides. Finding the offending code requires a
process of code analysis and possibly selectively commenting out sections of code to isolate the offender. Note: NetLinx modules
each have a DEFINE_PROGRAM section that must abide by the same rules as the main program, so the offending code could be in a
module.
