Upgrading Axcent 3 to Ni-3000
in AMX Hardware
This is my first upgrading of an Axcent 3 to NI-3000. Looking at the program I see that I only need to change the device addresses to the D:P:S standard.
The code complies (Netlinx) without errors.
I figure it's just pulling the Axcent, installing the NI-3000, load the program and everything should be fine.
I know it can't be this easy.....what am I missing? What's the logical approach?
I don't want to bring a knife to a gunfight.
Thanks for any input
brian
brian
The only thing I can think of off-hand is if you are using medium waits in your Axcess code. In Axcess, they timed out on their own, in NetLinx, they act like longs.
I thought there were a couple other Axcess keyword caveats, but I'm neither remembering them right this instant nor finding them online.
Speaking of online, doing a search on "axcess netlix" on AMX's tech note database turns up a handful of documents, a few of which address things to look for and/or keep in mind when going from one platform to the other.
- Chip
One thing that had me stumped for a few days were how string constants are declared. The example is for Hitachi projectors, ON command.
Axcess:
strProjOn = "$BE,$EF,$03,$06,$00,$BA,$D2,$01,$00,$00,$60,$01,$00"
NetLinx:
strProjOn[] = {$BE,$EF,$03,$06,$00,$BA,$D2,$01,$00,$00,$60,$01,$00}
It's just a syntax issue, but it had me thinking that my serial ports / cables were flakey. From what I can recall, the compiler didn't generate an error, leading me to believe that my code was okay.
It is probably documented somewhere, but I was too busy trying to get the swap done to hunt for such differences. I learnt my lesson.
Yours,
Roger McLean.
In NetLinx, these commands should be done in DATA_EVENTs ONLINE.
Thanks to all for sharing some valuable info
brian
