Home MODPEDIA - The Public Repository of Modules for Everyone
lifesize Icon 800 Modules
Hello All ,
did anybody used Icon800 AMX modules ?
I used , most of function work good except Input Select , for example when I send command "INPUTSELECT-1" to Module the video conference switch to input 1 and when you send "INPUTSELECT-2" it switch to input 3 , so did anybody figure out what is problem ?
  • AntAnt Posts: 54
    Hey,
    If you telnet into the unit you should be able to query all its available commands. Attached is the Lifesize 600 command set.
    Looks like the 600 uses...
    Auto videoPresentationSource input:int32
    Switches presentation input
    INPUTS
    input - Presentation input
    1 Input 1
    2 Input 2
    3 Input 3
    4 Input 4
    OUTPUTS
    _rv - Return status
