KNX is going Offline
                    I am controlling KNX devices using NXB-KNX gateway. I am using the built in module from AMX. Every commands working properly, the problem is when I am sending code to controller, the NXB-KNX will go offline. Then I have to make it restart to get online. Then sometimes, the command will work but it is getting delayed. From AMX controller, the command is firing but knx doesn't. I am using more than 600 actuators in module. Can anybody know what this problem is?
Thanks in advance
                Thanks in advance
