Changing Touch Panel ID
Is there a way to me to change the Touch Panel Device ID from telnet?
I know you can do it through the set up pages if you are in front of it.
Unfortunately I am not near the panel. It is a remote site.
Kenny A
  • vincenvincen Posts: 526
    HI,
    If it's a G3 panel or older no way to do that excepted SETUP Pages on Panel itself :(
    With G4 panels, if it's connected on network with a valid IP adress, and Telnet is enabled in Setup, you can telnet to it, issue a SET DEVICE command, it will ask you password (1988) and then you can enter new device id. Then issue a REBOOT command to get panel with new ID ;)
    Hope it helps
    Vinc
  • kennyannkennyann Posts: 113
    Thank you for helping me out. It worked great
    Kenny A
