Samsung Panels IP Reply
Hi Guys,
I've got a Samsung DB55E here that is performing commands sent over IP on port 1515 but not replying at all - has anyone ever experienced this?
Cameron
    Did you rule out a miswire of your rx wire on eiither end?
  • javery1javery1 Posts: 21
    Check the ID you're sending and the ID on the monitor. All connected monitors will respond to ID 0xFE, but none will respond.
    If I recall correctly, there have been models in the past that defaulted to ID 0, but would not respond to commands until the ID was changed. There have also been models that defaulted to ID 0 and did not allow a way to change the ID.
    All else fails, try updating firmware on the monitor.
  • CameronCameron Posts: 56
    Correct! I actually came back to say that :) Thanks javery1!!
