Network control of ControlSpace? ESP-1240 ??
Hi
In encounter a very strange issue with the Bose ControlSpace ESP-1240. If I control it in RS-232 no problem. If I switch to IP control it doesn't work anymore ! It receives my commands sent by IP (viewable in logs of ESP) but it doesn't execute them ! If I do it in Telnet it works so really confused here !
Did someone succeeded to control it in IP ?
Vinc?n[FONT=Verdana, Arial, sans-serif]rolSpac[/FONT]
    Can you post the code where you build and send the command via IP? Also, the correct command(s) that work with telnet?
  • vincenvincen Posts: 526
    ericmedley wrote: »
    Found the solution, in serial it needs only $D as specified in protocol but when you control it in IP you have to send $A,$D ;)
