Autonomic Module and TPControl for Android...
Hey all. I'll get right to it. So I have an MMS-2 that works pretty well. I have a wired panel in the kitchen, master bathroom, and basement and I am using the great fantastic amazing super duper Autonomics module.
It actually has been working really well. I also have it on an Android phone running TPControl. TPControl also runs really well. However, when I go to the pandora station list and start paging up/down through the stations; the app completely freezes.
Each panel IS running it's own instance of the module.
I have quoted out all other programming for all other panels, module instances, etc so that the TPControl is the only instance being used and it still freezes the app.
When I run telnet and msg on ...I don't get any errors when the app freezes.
One thing worth mentioning is that I didn't have a problem with the app before I changed the router out from an ASUS to a Ubiquiti edge router X.
Coincidence?...
Anyone have any ideas?
Thanks for any ideas you can throw my way.
    Well if you still have the Asus, put it back and see if the issue goes away. If it does investigate the Ubiquiti router fw and config.
  • yeah, that would be a good idea however it's dead and gone.
    Pretty sure it's the phone. It updated to the stupid lolli-pop OS!
    Tried it on another phone that is marsh mellow OS and it works fine.
    Thanks for your input...always appreciated.
